ML320 2002: Brakes Pads, Rotors and Sensors
Old 11-02-2015, 12:17 PM
MMMercedes's Avatar
ML 320 2002
Hello All,
A first time poster, looking for some advice and direction. Thank you in advance for taking the time to help me out.
My 2002 ML320 (108k on the odometer) - need to replace the brakes. Have been advised to replace pads, rotors and sensors for both the front and back.
To reduce cost, plan to buy the parts online. Looking for suggestions on:
brand
ceramic or metal
recommendation on where to buy from.
Any other information that might be helpful to a first timer. Thanks once again.
Old 11-03-2015, 05:01 PM
RayGon's Avatar
1999 ML320 Elegance
Originally Posted by MMMercedes
Hello All,
brand
ceramic or metal
So far, I have had a good experience with this brand and type and price is very competitive and reasonable (links below):
Amazon.com: Power Stop K2833 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive Amazon.com: Power Stop K2833 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive
http://www.ebay.com/itm/Power-Stop-K...JWG-AY&vxp=mtr
I hope this helps. Please do your own research also.
Old 12-01-2015, 01:54 AM
chkonski's Avatar
02 ml 320 w 163
hello,
I have problem with my 2002 ML320 w 163. I start the suv and everything is fine. After runing several minutes, 3 lights, (all thre together lighted ABS, ETS, BAS/ESP). Sometime the check lights goes off. car drives fine.... no other symptoms. Odometer works, fuel gage works, everything works. My local masters are stumped.
can you help me and say, at such time what is wrong ?
thank you in advance
sincerely, David
Old 12-02-2015, 08:56 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by chkonski
hello,
sincerely, David
You must have the codes read as there are countless possibilities that can trigger these lights.
Quick Reply: ML320 2002: Brakes Pads, Rotors and Sensors
