2001 ML 320 Rear Suspension Creaking Passenger Side
2001 Mercedes ML 320 (W163) Right Hand Drive
So ive got a nasty creak from passenger side wishbone area when going over bumps, etc. I've searched the forum and net and found the anti-roll bar bushes sometimes creak when dry, so have lubed these right up, but no joy in curing the issue.
Upon further investigation it look likes the main wishbone bushes are noisy whenever the wishbone moves up and down.
I've only had the car a month or so, and not long before the chap sold it to me, it had new wishbone fitted, and naturally the whole suspension that side was apart.
Is it simply a case of dropping the wishbone out and applying loads of silicone grease to try and provide some lube? Could the wishbone securing bolts be done up too tight?
Does anyone have instructions on how to take the wishbone off, any special tools needed?
thanks in advance,
thanks in advance,
As you can see in the video the shock and spring are located between the bolts for the rear upper control arm. To replace the upper control arm you need to remove the shock and spring. No special tools are needed.
I replaced my front shocks, upper control arms, lower ball joints, and outer tie rods myself. They all needed regular tools accept I had to use a torch on the tie rod bolts to loosen them.
chris-holland (07-14-2016)
Problem persists ! I've figured out it looks like the wishbone bushes for sure. I've tried disconnecting them, released the wishbone, greased up the rubbers with silicone, and still noise !
So, I picked up a decent second hand wishbone on ebay and went to fit it, but cant get the shock absorber to release from the wishbone. Ive tried some heat, smacking it with a rubber hammer, but no joy !
Anybody have any ideas how to release it?
Separating the suspension shock from wishbone
Thanks, but its the suspension release Im struggling with. Ive not played in a couple of weeks, but aiming this weekend to jack the car up and undo the 18mm nut on the bottom of the shock some, then smack it hard with a hammer. Any other ideas would be appreciated though !
