Abs esp bas light on help required
Old 11-11-2016, 11:33 PM
Pankaj Marwaha's Avatar
Ml320
My center support bearing worn out my mechanic unplugged abs cable from driver side rear tire ,he put my car on hoist and ran it to check which bearing was making weird noise after that abs esp bas and engine light turned on my car did turning steering right and left unplugged battery negative wire but still the lights are on if any one can help plz
Old 11-12-2016, 01:21 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Have your mechanic clear the fault----voila!!
Old 11-15-2016, 09:44 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W163 forum...
Quick Reply: Abs esp bas light on help required
