Heater has no heat, HELP
#54
2001 M 430
No, I could move the levers with no motor in place.
When I first installed rock motor, it moved the levers and stopped. (motor turning counter clockwise) controls were in off position. When I turned controls to heat-nothing to AC nothing.
#57
2001 M 430
yes I did. I wanted to make sure that the motor was warm and that I had heat, which I did, but could not get it to go back. When I removed motor and moved linkage back and forth by hand, I had heat and ac
#58
There are 3 possibilities.
Check fuse #16 to see if it is blown.
The Double Combo Sw. is not connected.
The Cont. Module N19 is faulty.
Caligirl (12-18-2016)
#59
2001 M 430
When I was checking fuses, before tearing everything apart or even ordering any parts, #16 was missing. I thought that the dealer might have removed. So I purchased 15 amp fuses and put one in.
I will check the double sw tomorrow.
How can I tell if Module is faulty and where is it located?
#60
They removed fuse 16. First check it again to see if it is blown. Then check to see if the Double Sw. is connected and check for 12v at the GREY wire with the eng. running.
#61
2001 M 430
I checked it today after all the back and forth, it is not blown.
I will check Sw,
Where is grey wire? at the blend door? There are many wires. I have a volt/amp tester.
I will check Sw,
#65
2001 M 430
Yes, I know that it is real late in New York, thank you for staying up so late trying to help me.
It is still yesterday here.
#69
2001 M 430
I did not disappear, my internet has been down for 4 days. Where I live in the mountains, I am lucky if I have power. (lucky I have a generator)
I wanted to let you know that I was able to get it working (with your help)
I thought about that #16 fuse and even though it was a new fuse I put in, I put a different one in. Then I unplugged and plugged in everything again. It worked just like it should.
You are AWESOME, I hope everyone that knows you realizes that.
I wish you a very Merry Christmas and a Happy New Year.
And please know I appreciate everything you did.
