Arghhh! Replacing ML350 Parking Lamp
Old 12-27-2009, 12:24 PM
Rauhbatz's Avatar
2007 ML 350 - VIN 4JGBB86E17A211020
Greetings MB world members...thanks to all in the past for helping me with my 1991 190 E 2.3 with 203K miles...still runs like a champ!
My wife's 2007 ML 350 has the left driver's side parking lamp burnt out. Dutifully reading the manualI set about to replace the bulb. Unlike the ease with I can replace bulbs on my 190 the parking lamp fitting is tucked between the front frame rail and the headlight housing.
Not having thin hands or wrists that rotate 180 degrees Ive tried small pliers, snap ring pliers and other small tools to move the bulb fitting counterclockwise to loosen it but there is not enough room to get it to turn all of the way. I think it needs a really llooonngg pair of needlenose but that seems like overkill for just a parking lamp.
Any steer from the MB World members be welcome...
Old 12-01-2010, 11:56 AM
dpulling's Avatar
2008 Mercedes Benz ML 320 CDI
No help with this? What did you do?
I think the solution is to pull out the whole lighting assembly, which means removing the bumper cover and grille. I've done this on a Prius. It seems absurd, but its the only way unless you have a child with long arms and strong fingers.
Old 12-05-2010, 10:29 PM
MAmendola's Avatar
2014 ML350 Bluetec,2012 C300 4matic sport
The easiest way is exactly what the previous post suggested. I thought my parking lamp was out on my 09 but it turned out to be something the dealer had to fix as the bulb was not burned but I kept getting a message that it was. At least I gained some experience if I ever have to replace the bulb
Old 12-11-2010, 12:09 PM
Benzo 003's Avatar
2008 ML350 4matic
Dollar store for that pair of long needle nose pliers.....worked for me.
Old 09-16-2014, 06:50 PM
penduboy's Avatar
2008 ML350
I know it is an old post. but found this video
http://www.carcarekiosk.com/video/20.../parking_light
Thanks, Pende
Old 09-18-2014, 11:40 PM
paul325740's Avatar
Ml 350
Thumbs up
Thanks, Pende
really helpful
Old 09-20-2014, 03:09 PM
beerj's Avatar
2006 Mercedes ML 350
Thanks, Pende
This has got to be the BEST help for this task short of taking it to the dealer and let them worry about it .
THANKS !
Old 10-02-2014, 05:01 PM
shiyunkh's Avatar
Mercedes ML350
Hey, do you know where I can buy that tool? that" long forceps" sorry I cannot hear it clearly,I don't know if I spell it correctly since English is not my first language and do you know what kind of bulbs should I use for 2011 ml350 for the parking light? Thank you very much!!!
Thanks, Pende
Old 10-03-2014, 07:24 PM
thunderbirl's Avatar
2008 ML350 4Matic
They are also know as a "hemostat".
Here's a link to a similar tool at Harbor Freight.
http://www.harborfreight.com/10-1-2-...amp-65711.html
Old 10-04-2014, 07:14 AM
Rauhbatz's Avatar
GREAT TIP ABOUT THE PARKING LIGHT!
Hard to believe that you need a tool used for surgery to remove a light bulb! What would Gottlieb Benz say????
Old 10-09-2014, 10:09 PM
20swrt's Avatar
ML 320 CDI
Ein Idiot dafür ausgelegt
Quick Reply: Arghhh! Replacing ML350 Parking Lamp
