Sign in using an external account
| M-Class (W164) 2006-2011: ML280CDI, ML320CDI, ML420CDI, ML350, ML500, ML550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: SL63
both headlights not worinig on my ml350
#2 |
Drives: 2008 ML350 4matic
maybe the dash switch itself....I think if it were a relay, you would get an error. But, if the switch went bad, the computer might not get the message that the lights are supposed to be on....
#3 |
Drives: SL63
turns out both headlights were burned out! my wife was driving the vehicle with only one light and didn't realize it. after the second one stopped working, she suddenly noticed there was a problem.
go figure. |
#4 |
but no error message.....odd.
#5 |
Drives: His 2007 ML320 CDI P3; Hers 2012 GLK 350 4Matic P1 Lighting Sports; Kids 2010 "4Matic" Impreza
Should have seen an error message on the dash telling you which bulb was out. Also these ML's have bulb substitution, so as a priority bulb goes out, the system raises the wattage on a nearby bulb (probably high beam in this case) to provide the needed illumination.
#6 |
Drives: SL63
there definitely was no error message.
#7 |
Drives: 2008 ML350
photonut,
I currently have the driver side headlight bulb not working on my 2008 ML350 (I did get the error message, luckily). I have 2 questions for you: 1. Did you take it in to Mercedes to have the light bulbs replaced, or did you do them yourself? 2. If you did them yourself, could you advise on how the bulbs were removed from the sockets? I tried removing the driver side headlight bulb from the housing and it would not budge. I tried turning it both counter-clockwise (as per the manual) and clock-wise to remove it and it would not turn. Any assistance you can give would be appreciated. Thank you, M |
#8 |
you turn the metal ring that holds the bulb in the housing....they are very specific which way is up....pay close attention
#9 |
Drives: 2008 ML350
Benzo,
Thanks for the info. as mentioned in my other post, i was able to change out the bulb by turning the bulb and harness 'hard' counterclockwise. it works! Thanks, M |
#10 |
Drives: 07 ml350
how to take out the headlight housing
i am trying to put some led strip light in the housing. can somebody tell me how to take the housing out from the body and how to take the cover away from the housing?
#11 |
Loosen the bumper cover and grill, remove the front fasteners by the fender splash shield, remove the 3 fasteners that hold the headlamp assembly, unplug harness. When you re install, take your time and align the fenders and headlamp gaps, and the side housing adjustment.
#12 | |
Drives: 2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI
Quote:
The ballast (or relay for xenon) is ~ 500 $ - also, I think I got message on board about light problem ... |
| Tags |
| 10, 350, benz, bulb, dash, edition, fuse, headlight, light, lights, mercedes, ml, ml350, number, part, replace, turning |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
