What does the ride feel like on 2009 ML?
Old 11-27-2011, 01:19 AM
cl55er's Avatar
2003 CL55 AMG
Is it cushy and comfortable or more on the firm/stiff?
Old 11-27-2011, 01:32 AM
togaclk55's Avatar
CLK55
Prolly more on the comfortable side...
Old 11-27-2011, 02:13 AM
tbal's Avatar
Haters crazy
Pretty comfortable. I think 2010s are even more Comfortable as airmatic suspension was available.
Old 11-27-2011, 02:21 AM
cl55er's Avatar
2003 CL55 AMG
thanks for the input guys. Was the airmatic an option?
Old 11-28-2011, 01:51 AM
medic's Avatar
2009 ML550
In 2009 the airmatic was an option. The non-airmatic feels comfy, not sporty. The ML can be lowered with aftermarket springs if you want, though. I moved from a 2003 FX45 Infiniti which had an amazingly sporty ride. There are + and - with both worlds. I miss the sportiness and the cornering of the FX, but I also like the smooth ride of the ML.
Old 11-28-2011, 08:04 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
IMO it's too top heavy and has a tendency to lean too much in a curve. The ride is comfortable but mushy and you don't get a true feel for the road. Granted, I'm running 20" AMG rims and Pirelli A/S tires which could also add to my dislike of how my 09 550 handles and rides. That's why I'm replacing my OEM springs with H&R progressive rate springs and may go further to coil over shocks if the H&R's don't make the difference I want e.g. lower CG, less body roll, stiffer suspension, better handling and etc. However, if you want a "family car like ride" then the stock non-airmatic ML (had it before on other AMG's, won't have it again) is a good choice.
Old 11-28-2011, 11:10 AM
roadrutz's Avatar
'09 ML550
My 2009 550 came with Airmatic as standard.
For the OP: If you find an ML with Airmatic, the ride is totally different than with the stock suspension. And at the push of a button you can switch from normal to plush to stiff and sportscar-like. It is one of the best suspensions I have experienced in almost 50 years of driving. (And don't assume that because I am an old fart I drive like one...)
But some people with older MLs have experienced expensive repairs to Airmatic systems.
Old 11-30-2016, 04:09 AM
flybd5's Avatar
2014 Smart ForTwo Passion Cabrio
Old post, but I regularly drive my 2009 ML550 on the German autobahn at up to 120 mph on cruise control. This ride is solid as a rock and very comfortable. The private resale value in Germany is about €10k higher than in the US.
Old 12-01-2016, 12:13 PM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
My 2009 ML63 AMG is also solid, no roll in the corners and very stable.
Quick Reply: What does the ride feel like on 2009 ML?
