Sign in using an external account
| M-Class (W164) 2006-2011: ML280CDI, ML320CDI, ML420CDI, ML350, ML500, ML550 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2011 ML350BT Grand Edition, 2011 Jetta TDI and 2010 BMW 335d
Change battery for Remote Key Fob.
#2 |
Drives: 2007 ML320CDI 2004 Jetta TDI
Replacement already?
#3 |
Drives: '11 ML350
#4 |
Drives: '09 ML550
#5 | |
Drives: '11 ML350
Quote:
It did cross my mind that the "replace battery" display was really triggered by elapsed time from when the car was placed into service just as a preventative measure. I don't have a battery tester for those button batteries so I can't say whether or not it the voltage was actually getting low. |
#6 |
Drives: 09 ML350 4MATIC
Had an 06 for 3 years and current have an 09 that I have had for 2 1/2 years. Drive the vehicle daily have never replaced the batteries in either key.
#7 |
Drives: 2011 ML550 Grand Edition (Chromite Black)
after only 10-11 months, I had to replace them...........I changed them, then within a month, the icon came on again...."replace key battery"....I had the battery checked, full battery power...Go figure..so I replaced them with a better brand CR2025....so far so good............
__________________
1999 ML 430 (126,000 KM'S) Traded-in... 2002 ML 55 (130,000 KM'S) Traded-in... 2006 ML 350 (40,000 KM'S) Stolen... 2006 ML 350 (26,000 KM'S) Traded-in... 2010 ML 350 (Tenorite Grey Metallic) Traded-in... 2011 ML 550 (Chromite Black-Grand Edition) |
#8 |
Maybe I use the key fob to open the rear tail gate too often thus causing the battery to run low?
In my 335d my key fob's battery is still good after 2 years but there is no auto-trunk opening on the D. It could be a bad batch of batteries? The CR2025 is similar to the CR2032 which is used on computer motherboards and these lasts for many years. |
| Tags |
| 05, 2001, 350, battery, change, changing, class, fob, key, mercedes, ml, ml350, remote, replacement, sl500 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
