I could really use some wiring help...
Copy'ing the headlight mod from another thread. However, I'm in the US vs. the OP being from Australia, so things are a little different for me.
I've got the headlights out, and am trying to wire in an LED strip that is going to be a combo DRL and turn signal. See this thread for what it is:
https://mbworld.org/forums/m-class-w...-mod-pics.html
I've got three wires coming from the LED strip. Red (white led), white (amber led), and black (presumably ground).
If I wire to the corner turn signal bulb, like the OP did, my LED strip is constantly on AMBER. If I hit the turn signal, its blinks with the WHITE led's.
So...figure maybe my wires to the LED strip are backward, so I switch them, but I get the same result. The AMBER seems to be a constant ON coming from the corner turn signal.
So I have two questions...
- What is the proper / best way to wire this? Could I wire to the turn signal that is inside the socket of the long turn signal (which is now becoming the LED strip)? And then I don't want the corner amber turn signal to be on at night (which I guess it is here in the US). Could I just remove that bulb, put in a resistor, and call it a day?
- Is there a way to hookup to STAR and change the light setting to Europe to turn off the corner amber turn signal from being constant on? I know we were able to do this with Audi's, so thinking this would be the same with MB, but I'm not sure.
ANY help us much appreciated!!
*Does anyone see anything wrong here (please excuse the crappy temp wiring).
