LCD in Dash Display
LCD in Dash Display
LCD in Dash Display (Cross posted from X164 since the dash is the same)
Is there any fix or replacement for the LCD in the dash between the speedo and tach?
Mine just showed some bad pixles lighting up yellowish when they should be black.
UPDATE: The area of bad pixels is getting bigger.
Help!
Help!
Bump!
Asking here since there are a lot more MLs then GLs so hoping someone has the answer.
I found a replacement LCD I might try installing myself, bit was wondering if anyone has a step by step to pull the cluster?
It probably is not hard, but rather than risking buggering up the finish, any tips on types of tools and such would be appreciated.
