white battery message after disconnection of the battery
Old 12-13-2014, 12:51 PM
willlib's Avatar
ML320 CDI 2008
after I disconnected the main battery and clean the negative post, I got a battery logo in the message center. I look the voltage and the charging with the indicator on the vehicle and everything is fine. How can I clear that message. thanks
Old 12-14-2014, 04:21 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
There is a second battery near the main battery held down by a clamp. That's what is bad. Replace it with Interstate SLA 1005 which is a 12v 1.3ah AGM battery.
Old 12-15-2014, 09:46 AM
willlib's Avatar
ML320 CDI 2008
you are right, that was related to that battery. When I cleaned the post I removed that connector after reinstallation the contact was bad. I pass a sand paper on the contact and squeeze the female side just a little bit with a plier, the message is now gone. thanks
Quick Reply: white battery message after disconnection of the battery
