AUX-Bluetooth adapter?
I am picking up my 2007 ML 500 and have figured out already that it doesn't have bluetooth (other than the puck, and that is only for the phone), so I will either be playing my music through an AUX cable (can that run out of the glovebox without trouble), or using a AUX to Bluetooth adapter. Has anyone used one of these with your M-Class and have any recommendations?
No, you use your phone's bluetooth connection to become an AUX-in and then use your phone to control the music, calls, etc. Basically, just like using an AUX cable without having to connect the cable. Not optimal (and less safe), but a bit less hassle than using the AUX cable. And, they usually have built in mic's for calling out and some basic music controls on the physical adapter. Here is one example:
