ML350 bluetec engine issue after intake replacement
Old 01-07-2015, 04:39 PM
jclemen's Avatar
2003 e320
Delete
Old 01-07-2015, 05:15 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Must have lost oil pressure for one reason or another at some point.
Why were the intakes replaced?
Old 01-07-2015, 05:50 PM
jclemen's Avatar
2003 e320
Delete
Old 01-08-2015, 09:46 PM
20swrt's Avatar
ML 320 CDI
Intake motor (only 1) is located outside the intake manifolds. Its located somewhat underneath the turbo - in between the V banks of the cylinder heads. Some skilled mechanics can actually replace this intake motor (aka swirl motor servo) without removing the intake manifold. What is inside the manifolds are just vanes that look like butterfly valves on each cylinder. The valves could get stuck because of carbon buildup - that might be why it had to be opened. Did the indy tell you they could have bypassed the servo motor with a simple resistor and saved you $$ ? These OM642 motors are not known to fail like you describe. Yes they can easily go 120K as long as it is maintained by competent mechanics. Most catastrophic failures like yours are usually caused by human error. Sorry about your loss. Have the oil pan dropped - if possible - be present when that is done. You might find real gold in the oil pan . Kidding aside - to make sure what actually caused the problem.
Quick Reply: ML350 bluetec engine issue after intake replacement
