Liftgate Only Opens Half Way
Old 03-01-2015, 01:41 AM
Genjet's Avatar
1993 190E, 2011 ML350, 2014 ML350, 2003 BMW 540i, 2013 GLK 350, 2014
Whenever I use the remote or door switch for the liftgate, it goes up about half way and then stops. It will then go down and lock normally by either switch. The only problem is that it opens half way.
Not sure if it's coincidence but I changed both batteries yesterday. Both were removed at the same time so I had to re-program some of the windows as instructed in one of the forums. Maybe a re-programming is needed for the liftgate? I tried to research the forums and the internet but have found no solutions.
I did come across a thread that mentioned an electrical drain in the liftgate area and the rear fuse box under some circumstances. It mentioned the dealer doing a software upgrade to something in the rear fuse box.
Beginning to think the battery icon I had earlier was a result of a constant drain. The auxiliary battery did test bad, but maybe it was due to something in the liftgate system that caused it? I guess with new batteries, time will tell..
Old 03-01-2015, 07:40 PM
06e320cdi's Avatar
2008 ML320CDI
Under the menu in the Info display, go to convenience or vehicle settings and look for the one for liftgate. It might have reset to lower/limited opening.
Old 03-01-2015, 09:44 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Re-program it..manually lift all the way up...press and hold button...check your manual for proper procedure
Old 03-01-2015, 09:55 PM
Genjet's Avatar
Thanks for timely information. I first scrolled to the settings page and changed the liftgate limiter to off. Now all is good. Appreciate you fellow members!
Old 01-16-2019, 10:48 PM
Adrian Popescu's Avatar
Amg c43 2018
Hahaha, you my friend, are THE MAN! 😁 I completely forgot about this feature... was going to call Mercedes in the morning...if it wasn’t for your note on this forum
Old 01-17-2019, 02:52 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
The limiter is so your liftgate doesn’t hit top of garage door opening or the garage door itself. Check if this could be a problem.
Quick Reply: Liftgate Only Opens Half Way
