How do you reset the brake wear indicator on a 2008 ML350?
Old 03-21-2015, 04:30 PM
MBBreeze's Avatar
2000 clk320 2008 ML350
How do you reset the brake wear indicator on a 2008 ML350? Thank You in advance for any input. David
Old 03-23-2015, 07:27 AM
STLML350's Avatar
ML350 Blutec
The brake sensor is replaced when you put new brakes on and the light goes away.
Old 03-23-2015, 11:32 PM
MBBreeze's Avatar
It finally went out on its own the other day but yesterday it came on while going over a bump and went out a while later. Today it did the same thing. I will look at the wear sensor tomorrow to see if it is loose or see what else is going on.
Old 03-24-2015, 07:35 AM
STLML350's Avatar
ML350 Blutec
It will go and off spraticly until it stays on. Unless you have done your brakes lately you need to get them done.
Old 03-24-2015, 07:41 AM
MBBreeze's Avatar
All pads, rotors and sensors are new.
Old 03-24-2015, 07:51 AM
06e320cdi's Avatar
2008 ML320CDI
Sounds like a defective sensor, or bad connection
Quick Reply: How do you reset the brake wear indicator on a 2008 ML350?
