Pull engine out 2006 ml350 balance shaft repair
Old 04-10-2015, 11:17 AM
ducryder1's Avatar
2006 ML350
After reading engine removal instructions on WIS it only shows dropping it out from the bottom. Has anyone pulled the engine out of a w164 from the topside or is it even possible?
Old 04-19-2015, 08:22 PM
framer's Avatar
2007 ml350
does the engine need to come out? maybe just remove radiator and front shroud and support to give you room to slide out shaft?
Old 04-23-2015, 06:26 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Oh no...that would be too easy.
Check a thread from user sickspeed Monte or something like that.
He did his W203.
Sadly the shaft unbolts from the back.
If you decide to DIY be sure to get FRESH sealant.
Just was discussing this yesterday.
Mechanic pulled an engine, did the work, and then the engine leaked like a sieve.
M272 doesn't use gaskets for the oil pan, or valve cover.
Uses some sealant from MB, but from what I hear you gotta check the date code on it,
if it's old, it won't hold.
Old 04-24-2015, 01:36 PM
SPONSOR
PelicanParts.com's Avatar
Feel free to give us a shout and speak with a Mercedes specialist that might be of some assistance if you don't find anything on the web.
-Luccia
Quick Reply: Pull engine out 2006 ml350 balance shaft repair
