Radiator Fan Not Running on 2008 ML 550
Any of you guys have a wiring diagram for the radiator cooling fan circuit and a fuse box layout legend. Info on line is nearly impossible to find. At this point the fan will not run and I have zero tech info to work with.
Open the hood and at the Pre-Fuse Box tell us how many RED wires are coming out of the bottom. Photo will help.
Pur, I am trying to help help but your answer of 3 or 4 does not help me.
Aside from from that huge RED cable, how many other RED wires are there?
Do you own a DVOM (Digital Volt Ohm Meter) or a test light, preferred?
Cooling fan
I have a fuse tester a 12volt one and I just checked the harness plug to the fan and it has power but the fan still don't come on and the thermostat is new
its 3 red wires one looks red but it kinda don't ..that how come I said 3 our four I took a picture so you can see ..and my friend thank a lot for your help also im still try to learn the page
Turn the key to the on position and at the fan connector, test the RED & PINK wires for 12v and then check the BROWN wire for ground.
Cooling fan ..thanks
- [QUOTE=Maj. Dundee;8264543]Turn the key to the on position and at the fan connector, test the RED & PINK wires for 12v and then check the BROWN wire for ground.
Ok sorry about the late reply im just working so much ill try but I believe I've done it with the test light and the ground brown when I hook it to a power source the tester does light up and the red also when I grounded it has also lit up ..i just don't remember if I had the key turned
Last edited by Pur Childs; 02-13-2021 at 08:24 AM. Reason: Wrong message made a mistake
