Boost pressure regulator problem :(
Old 08-31-2015, 03:53 PM
Ronny Holm's Avatar
Mercedes ML
Have some problem with the turbo boost pressure. I have changed the Boost pressure regulator and the problem is still there. A friend of me have an DAS and it tells the problem is Ground to short. Some problem with the red and green cabel is short to ground. The voltage between 1 and 2 should be 12 - 14 V but it is 0.75 V. Where does the red and green cabel end?? So I can make a test there. Any ideas?? (Mercedes w164 2007)
Old 09-01-2015, 09:25 AM
Ronny Holm's Avatar
Mercedes ML
Anyone??????
Old 03-24-2024, 05:31 PM
grygarek's Avatar
w211 E 320 CDI 4-matic (211.089)
Hi, probably I have same problem, could you share information with me, please ?
Quick Reply: Boost pressure regulator problem :(
