2011 ML550 check engine light P0128 code
The check engine light came on and the OBDII code reads P0128 "Coolant Thermostat (coolant Temp Below Thermostat Regulating Temperature". I want to change the sensor since this is the cheapest way to experiment, before looking into changing the thermostat. Can someone tell me where the sensor is located on a 2011 ML550? A picture would greatly be appreciated. I'd googled it and doesn't seem to get anywhere. Thanks in advance for your help.
