W164 Rear Brake Rotor Replacement Torque Specs
Old 01-18-2016, 10:30 PM
gotiger95's Avatar
2000 CLK 430, 2009 ML 350 4Matic
Can anyone point me to the torque specs for the rear calipers when replacing the rear rotors on my 2009 ML 350 4Matic? I have searched and can find the info for the front brakes but not the rear. Even better, is there a posted procedure for rear rotor replacement that includes the specs? Also, does anyone know if the rear caliper bolts need to be replaced or can they be reused? Thanks!!
Old 01-19-2016, 04:04 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Torque specs=Stage 1 60 Nm-Stage 2 45 degrees.---do not kink the brake line!!!!
The rear bolts can be reused!!
Old 01-19-2016, 05:48 PM
gotiger95's Avatar
Thank you Plutoe! So it is the same spec as for the front caliper bolts. One more question...I assume that the guide pins are also same spec as the fronts...55 Nm?
Old 01-19-2016, 06:46 PM
Plutoe's Avatar
1999 E300TD
Nope,rear guide pins=25Nm
Old 01-20-2016, 12:02 PM
gotiger95's Avatar
Thank you!!
Quick Reply: W164 Rear Brake Rotor Replacement Torque Specs
