Front drive shaft question
I removed my front diff to be rebuilt. During removal the shaft was stuck in the piņon collar due to corrosion. The joint came a part with steel ***** rolling out . Can you reassemble the joint or due you have to get another drive shaft? Has an one else in the front diff failure club dealt with this?
I will answer my own question
I have completed my diff rebuild. Yes you can reassemble the joint. I did with some patience. But it was a wast of time. When I ran the car it had a bad out of balance vibration. Had to replace the drive shaft. Also the transfer case side was also rusted in and broke coming out. If you are doing a diff on a car used in road salt country you will need a drive shaft.
Did you install a brand new shaft or used one? Fallen apart cv joint happened to me on my R350 as well. I put it all together back, but now I have some vibrations when accelerating around 2000 rpm. I din not drive this car before that fix, so I don't know if that vibration was there before front diff. replacement. I am trying to figure out if that drive shaft cv joint can be a problem.
Can you describe your out of balance vibrations you had?
Thank you
Thank you
Hard to describe
Based on how hard it was to get the shaft out of either side. I decide that a
Donor car exposed to road salt would have a high risk of damage during removal
So I bough a new one from .http://www.wholesaleimportparts.com good prices and service New one was 327 with free shipping
The vibration is hard to describe. It is more a sound of something vibrating then a feel.
If your joint came apart I would be thinking you have a shaft problem
