Transfer Case Fluid vs. Transmission
Hi guys,
So my vehicle is a 2007 ML350 (4matic) with only 65,000 miles.
The transmission fluid was changed at 39K miles per Mercedes.
I just changed the front and rear differential fluids.
But now that I got the vehicle back, I'm wondering if I need to change the transfer case fluid. At what mileage or age does the transfer case fluid need to be changed? Or I am "good" since I already changed the transmission fluid?
Thanks!
Thanks!
2008 ml 320cdi
Further to that,
Are there simple drain/ fill bolts on each? I assume a small bottle pump would be necessary.
Canadian dealer tells me they pump out of bottle also- no bulk.
i am pretty sure there are simple drain and fill holes on it, takes my mechanic 5-10 minutes to drain and refill
and the transfer in my 2008 GL takes mercedes transmission fluid
