ML 350 2006 antitheft alarm system sirene don't horn
ML 350 2006 y. USA ver. VIN 4JGBB86E96A131558
Hello, my name is Martin and I write to You from Poland, Europe. I just bought ML 350 2006 y. USA version (but used in Europe, someone imported car).
I would ask You, about antitheft alarm system. When I turn on alarm, the lights are flash but the sirene are silent! I check the fuse (all is ok), SD computers don't show any errors with this system, and I remove sirene and check with car battery and she gave the horn. Where I can find the solution? thanks!
What you have is fully functional alarm. Only signs of a dead alarm is faulty locking, false alarm trip and battery drain.
Sadly when originally built there was no audible sound. (In U.S models)
That being said you can buy a new generation alarm module and yes they do have a low level electronic beep on lock/unlock accompanying the lights. The beep is not loud at all and sometimes isn't heard from the rear at all unless you're very close in a quiet area
