Washer fluid squirter inline pressure regulator?
I've had an issue with my 2007ML shooting washer fluid out only only nozzle, and some shooting out of in all directions.
I found what appears to be a plastic valve or pressure regulator of some sort. It is inline with the fluid hose. It was cracked and when I pulled it out I caught a brief view of a rubber gasket that popped out and disappeared into the engine compartment.
I put it back together and sealed the crack with some rtv silicone... so the leak is gone, but now there is nearly no pressure to the passenger side nozzle.
Any ideas as to what the part is called and where I could get a replacement?
Thanks all.
Thanks all.
Am out of Florida till Wednesday and upon return will be able to investigate the issue!!
