Another oil leak
Another oil leak
Replacing turbo inlet seal I noticed small oil leak on vacuum pump. Small amount of oil is escaping on top of the pump between the cover and pump housing. Is this common problem and something easily fixed? Is there a gasket that needs replacement?
Thank you!
Thank you!
