Sign in using an external account
M113 V8 Kompressor Platform Technical discussion relating to models sharing the M113 V8 5.5L Kompressor. Including SL55 AMG, CL55 AMG, S55 AMG, E55 AMG, CLS55 AMG, G55 AMG, SLR (M155). |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: SL55
Engine looses much oil on the left/top side
#2 |
Drives: 2003 E55 AMG
Valve cover gasket?
#3 |
Drives: SL55
Dont look like its coming out there. There is alot of oil , must be something bigger i think. I need to fillup 2L after 100mls cruising
#4 |
Drives: SL55
Removed SC and i see where the oil went.
#5 |
Oh damn! Where is it coming out from though?
#6 |
Now that you removed your s/c, take a look at the wiring harness for the throttle body and the recirculating air flap. I found mine to be cut due to excessive heat behind the engine.
#7 |
Drives: SL55
Dont know. I think the valve cover gasket is the problem.
I will change all gaskets and check again. I have no faults. Should it throw error when there is a cut ??? |
#8 |
Well, it did not throw any on my car. My s/c wasnt engaging, star gave me code "M16/7" recirculating air flap fault. So before I bought the part, I checked wiring from the comp to the plug, and found the brocken wires.
The wiring harness for the throttle body and the recirc air flap are routed behind the engine, tie rapped against the engine and transmission. It gets super hot back there, so over time it will burn through the shielding and eventually to the wires. My car is an 03 with 110k miles, so maybe Mercedes noticed and rerouted them on other years. But wouldnt hurt to check. Will save you headaches if you catch it before it happens. |
#9 |
Drives: SL55
ok, will check that also. But first i need to find the oil leak.
#10 |
Yes, thats priority. Thats a lot of oil for it being from the valve cover gasket.
#11 |
Drives: SL55
I changed the valve cover gasket and other gaskets. Now there is no oil but this hole (yellow marked) makes me nervous. Its open but there is no oil coming out when engine is running ???
#12 |
I see. Does it end somewhere or does it go somewhere?
__________________
#13 |
Can you take a pic of top view?
__________________
#14 | |
Drives: s55 AMG
Quote:
Cheers! |
| Tags |
| 2012, air, currnet, cut, engine, flaps, left, lefttop, market, oil, price, sl55, valve, velve, w163 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
