M156 V8 Platform Technical discussion relating to models sharing the M156 V8 6.2L engine. Including SL63 AMG, CL63 AMG, S63 AMG, E63 AMG, CLS63 AMG, C63 AMG, CLL63 AMG, ML63 AMG, R63 AMG.
CL63 AMG MAJOR ENGINE FAULT
Old 01-15-2016, 01:06 PM
college66's Avatar
Mercedes CL63 AMG
Hi all,
Following Star diagnostics yesterday ( see below), carried out by a local Indy, can anyone offer me any advice please and what my options are, I.E new engine, re-build etc. The car has only covered 81,000 miles and has full MB service history.
Fault codes for misfiring on cylinders 1,5,6,7,8 in fault memory as well as
0760 (Left intake camshaft Hall sensor):The time of the signal value change
is implausible
Cleared fault memory and after cranking the fault code 0760 had returned.
Carried out compression test on Star. ECU reporting RPM difference of 267
RPM, maximum permissible difference 28 RPM. Suspect internal engine
damage with fault code 0760 perhaps indicating camshaft timing is out.
Old 03-28-2016, 08:39 AM
Amgm156's Avatar
CL 63 AMG 2007
Hi
Friend
I have same problem see The fault codes
Sorry for The language because i am from Holland
Old 03-28-2016, 08:58 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
This is a triple post be patient!!
Quick Reply: CL63 AMG MAJOR ENGINE FAULT
