Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Mercedes Tech Talk > M275 V12 Bi-Turbo Platform
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-04-2011, 03:24 AM   #1
Oxygen's Avatar
Drives: W220 S65 AMG
Send a message via AIM to Oxygen
Question W220 S65 - Weird Start Problems
I noticed this is starting to happen more often, at first I thought it was just something off.
This does not happen every time, but sometimes, especially if car has sat for a while when I go to start it, it will crank a few times then basically it stops and the RPM gauge goes all the way to max and then back down. Turn the key to the off position and attempt start again, it fires right up.
Sometimes it does this when it's hot, sometimes it does it when it's cold... I thought maybe the battery was going bad so I bought a new one, same behavior.
Any ideas on what this could be? I saw nothing out of the ordinary when diagnosing with SDS. Starter? Fuel Pump? Coil? Spark Plugs? Some sort of a sensor?
To remove this ad, register today or login if you already are registered!
__________________
https://www.facebook.com/v12TT
| Past Cars: Photos
| M275 V12 biturbo technical resources (under construction): www.v12tt.com / www.v12biturbo.com
| YouTube: S65 AMG Video
Oxygen is offline   Reply With Quote
Old 11-04-2011, 06:58 AM   #2
FormulaZR's Avatar
Drives: Yes
Do any other lights/gauges act stupid when this happens?
If not, could it be a crank or cam position sensor acting up?
__________________
FormulaZR is offline   Reply With Quote
Old 11-04-2011, 10:01 AM   #3
Oxygen's Avatar
Nope, only the RPM gauge goes to the top and then back down.
The sequence is like this: CRANK>CRANK>RPM MAX>STOP happens in a matter of about 3 seconds.
__________________
| Past Cars: Photos
Old 11-04-2011, 10:25 AM   #4
Drives: 1994 Toyota Supra, 2005 CL65
I had the same problem in my CL65. I use the keyless and go and I hit the button on the gear shifter and it did the exact same thing. Did it 3 times in a row and then the car finally started. This has happened to me maybe 4 times in the past 3 months. It hasn't done it for the past 9 weeks though so maybe it was just a minor hickup. Keep us posted on your progress.
R.K.
radride is online now   Reply With Quote
Old 11-04-2011, 10:27 AM   #5
Oxygen's Avatar
Okay glad I am not the only one! I stopped using KeylessGo when it first started doing it, seems to do it more often with the KeylessGo than it does by using the key (maybe that's just my imagination?)
Anyways, looking at this thread: http://mbworld.org/forums/3688172-post11.html seems like it might be a bad coil pack also.
__________________
| Past Cars: Photos
Old 11-04-2011, 11:38 AM   #6
Drives: 2007 E550 4-Matic, 2004 SL600
My SL600 has done it a few times using the KeyLess-Go, turning the car off and then hitting it again causes the same, but holding the button down to start, it starts right up, or using the key.
That said, I've had misfires also, finally found a decent tech and he reproduced the misfires and is replacing the drivers side coil pack. Will know more when I get it back, hopefully next week. From other posts here it may resolve this starting issue also.....we'll see.
__________________
mkhurley is offline   Reply With Quote
Old 11-24-2011, 06:15 AM   #7
andymlow's Avatar
Drives: CL600
Just had a no start this week on my 07 CL600. Cranked great but no start. Got towed to the dealer and the next day it fired right up for the tech. Unable to find any issue to explain it. Looking thru the NetStar, the car had 2 no starts prior to my ownership. On the first the starter was replaced and the second the battery. I'll bet it was the same issue and they were guessing at what caused it. Anybody else with weird starting issues on the biturbo 12?
andymlow is offline   Reply With Quote
Old 01-05-2012, 11:08 AM   #8
Oxygen's Avatar
Update... I changed my oil and it starts perfect every time now... Key or KeylessGo... what the hell?
__________________
| Past Cars: Photos
Old 01-05-2012, 11:09 AM   #9
Oxygen's Avatar
Maybe it's the colder temperatures?
__________________
| Past Cars: Photos
Old 01-11-2012, 08:18 PM   #10
Drives: S65 AMG
My 2009 S65 also does this occasionally. Taking it into the dealer to see what gives.
rennvader is offline   Reply With Quote
Old 01-11-2012, 08:53 PM   #11
Shifter's Avatar
Drives: ///AMG
I know your problem. You need to have the flywheel greased with special grease...dealer will know this.
Shifter is offline   Reply With Quote
Old 01-12-2012, 07:43 PM   #12
Drives: cl600
i've heard some keylessgo get stuck, or stiff and need to be replaced.
biker349 is offline   Reply With Quote
Old 01-12-2012, 09:05 PM   #13
Drives: S65 AMG
Service advisor requested that I bring both keys in so I think you may be onto something with Keyless Go.
Old 01-17-2012, 06:22 PM   #14
Drives: cl600
so what was the outcome?
Old 01-17-2012, 07:14 PM   #15
Drives: S65 AMG
Dealership says they cannot reproduce and there are no error codes; so no idea...
Old 04-05-2012, 11:39 AM   #16
andymlow's Avatar
Drives: CL600
It died at the dealer as they were returning it to me
They ended replacing the engine computer and the keyless go computer and it is still having trouble
Sometimes no crank and sometimes crank no start
Old 04-15-2012, 11:22 AM   #17
Oxygen's Avatar
So what you're saying is no one actually knows what's going on?
__________________
| Past Cars: Photos
Old 04-15-2012, 12:53 PM   #18
andymlow's Avatar
Drives: CL600
That is absolutely correct. Now they they think it could be the main wiring harness which takes 50 hrs of labor to replace. I'm thinking of trading for a new A7 or used M6
Old 04-24-2012, 06:19 AM   #19
Thericker's Avatar
Drives: V12-Biturbo
Quote:
I had exact same symptoms on my past S-class w220 turned out to be Crank Position Sensor.. (Someone already mentioned this may be cause 5-7 posts ago)
Thericker is offline   Reply With Quote
Old 04-24-2012, 06:57 AM   #20
andymlow's Avatar
Drives: CL600
That was the first thing they replaced long ago. I think they have it doped out now. It was a unit called the SAM or signal acquisition module that sits under the fuse panel in the engine compartment. They had the car running and jostled the SAM and the car went totally haywire. I'll know more in a few days but it seems promising.
Tags
cl600, coil, crank, m275, mercedes, off, problems, s65, start, starts, stops, taking, turns, w220, wont
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
