View Full Version : C-Class (W203)
- Does anyone have any info on the C350 6 speed bi-turbo?
- Driving with my supercharger not kicking on suxxx...
- 2002 c230 sunroof visor question
- new guy audio ?'s
- C320 Wagon Seat Question
- Inductively energised key, handshake & start process
- Leak on drivers side
- Anyone no where I can get a service manual for a 06 6 speed manual trans?
- W203 CL grille idea......
- Headlights are always on.
- Where to buy DEPO's?
- Calling out....granite gray c class on Ventura bld , in Encino
- HELP! Should I buy these!!!!
- Head Lamp Adjustment
- Key unlocks doors but wont start car
- need help diagnosing possible faulty torque converter
- Good Info
- Certified...help me decide who is bs'ing here
- 18" wheel question, need your opinion please.
- FS:2005 C55 AMG (NYC LOCAL)
- M111 Supercharger Pulley Upgrades
- Project: 2006 C230 Sport - Black & Grey
- Did the dealership just break my car???
- About to upgrade my comand
- Exhaust Shop Needed in Miami area!!
- remove some scatch
- Saw the C204 Coupe up close today. Whats your opinion?
- Intermittent start/crank issue
- glovebox sagging on the right side
- Can i buy it?
- 2001 C240 Bogs Down
- 2004 C230 Kompressor air intake.
- Instrument Cluster
- I just finished browsing 100 pages of threads in this forum...
- Italian Mercs and more...
- SPLASH!!!
- 2005 MB C240AWD, How do you reset the Service B Maintenance Alarm coming up on the...
- maybe a new c class owner...need help
- Replaced all 4 control arms now "ESP is not available, visit workshop!"
- FS: Eaton M45
- 18" ET32 problem
- Strange Noise: Timing Chain
- is there a fuse for the cd changer?
- New Wheels Lug nuts are too long!!!
- help. srs display faulty
- Fuel Filter Question
- Anyone have a shifter linkage diagram or pics for a 6sd manual
- '05 C230 Kompressor idle dipping, a/c and radio cutting out
- FS: C32 Front Sway, Front Rotors
- how to remove interior pieces?
- Morimoto H1 to Morimoto FX-R 2.0
- Trade 2007 C-230?
- Show me your W203 with a different grill!
- New guy, I have a couple questions before I start modding.
- 2002 c230 coupe
- Suggestions for a cash strapped student's C240
- $428 for ONE Smart-Key ?
- Broken Alternator Bolt
- 18" 19" ST180 ST181 Wheels Group Buy $599 Shipped
- New rear brakes, new problem!
- side signal
- DTC P0446 Code
- Wheels and Tires
- overhead console not talking(or listening)
- Wiring CCFL RINGS
- ECU REMAP
- H&R co's or Megan co's or h&r with konis
- Limp mode problem
- Tapping into the rear sam for accessory(remote) wire
- Dropping by..
- Xpost: different colors from same OEM HID bulbs; WTF?
- 04 C230K - not shifting from 1st gear
- P0020
- Removing SC silenecer at a shop ?
- W203 Front Conversion to S-Class
- What is this ?
- Display shows door open when closed
- need 6 numbers ss sport package car
- What do you like about your W203?
- Extremely dim information center
- just fell in love......
- Air only blowing on feet after re installing COMAND
- Another 'Undervoltage' problem with a new twist
- Part # for after 05 ashtray rubber mat w203
- the time has come...
- Bought Rear Brake Disc online
- C230K fuel pump problem
- Headliner
- Best tire size for this wheel (c320 4matic)
- Folding Spare Tire: Replace
- Help - Cranks but no start - DTR
- Help Needed Locating Fuel Sending Unit (WIS would be nice)
- Audio Install (Bose)
- C55 gauge cluster
- Front Bumper on C230 Coupe Parts
- P0420 with Kleemann cat again!
- new guy with 2006 c230 sport
- what is the best bang for buck modification on c230 '05 kompressor??
- rain sensor adjustment
- will it throw code on c230 '05 if I remove my cat?
- Shift knob!
- koni fds kit
- Performance tuning for c230 '05 kompressor sedan!
- Service B
- Installing subwoofers in c230 w/ COMAND?
- FS: OEM 19' BRABUS MONOBLOCK VI
- How to tell if you have 2003 C230k sedan Sport Package?
- Plastic Jungle - The photoshoot (wagon content)
- Ebay Smarkey replacement anyone?
- Problem fitting new rear brake pads.
- Mercedes C32 Hood emblem question
- A few general W203 questions
- what part or part #?
- 03 c320 mod progression
- Can I use the power from cd changer to splice extra cigarette plugs?
- FX-R Retro
- Problem with volume control on COMAND
- Transmission cooler leak at fitting
- sideview mirror turn signal
- Carbon Front Lip on a normal Avantgarde? Does it fit?
- Help me decide on a grill
- w203 wagon fuel economy
- New England Meet?
- FUEL SENSOR / FUEL GAUGE VAL
- For those that have changed front struts....
- Help please - Radiator issues
- W203 Wagons--pay or play?
- brake experts, please help me from going insane
- So you've always wanted a set of '07 Sport wheels?
- Activating COMAND unit?
- Help! 2003 C230 grinding noise with new rims
- 2003 c230 k unknown noise and vibration comes on and off
- Stripped Wheel Hub Thread / Helicoil users chime in
- Troubleshooting Engine Vibration
- FUEL SENSOR / FUEL GAUGE VALVE
- MERCEDES C240. 2002. FUEL SENSOR / FUEL GAUGE VALVE
- Poor C240 start problem
- Broken Door handle help
- 2002 C230K reliability and safety
- Bedtime reading if anyones interested
- Rumbling sensation when slowing down. Also very slight steering vibration on breaking
- Check Engine light ! NOO
- Confused on which used C-Class 4matic to buy!
- FS: H&R coilovers
- Need torque specs for brakes
- Question: what is the electrical humming after engine is switched off?
- Sunroof malfunctioning? Use/try this...
- no A/C part 2
- Bay Area August 5th car meet MBworld roll call
- Hiighway Vibration with a rumble!
- Front Sway bar link part number? 2003 C320 4matic
- Constant cold air in footwell when AC is on??
- Part number request
- Size of screw to hold license plates
- B service
- 2007 c230 speaker not working
- No Turn Signals and headlight failure 2003 c230
- How to troubleshoot radio antenna?
- 2005 MB C240 AWD, Serpentine Belt wobbles after changing Alternator, how can I fix!
- Just had drive belt replaced.
- [SOLVED] Please help me identify this, coolant hose to engine
- Floor mats
- Part number for overhead console w/SOS?
- 2002 Mercedes C32 I NEED HELP
- Weird ac problem in my 07 C230
- Tail Lights
- Europlate ideas
- DIY: M271 Idler & tensioner pulley
- Need passenger seat cover!
- Lip Spoiler from "formymercedes.com"
- What do [did] you look for in a car?
- Engine Shutter/shake
- New Guy
- MB audio 10 poor radio reception.
- Key won't turn
- Oil level check
- C240 Sounded Like a 240D - LONG
- So Long W203
- Please help with my foglights
- C320 Hood won't open!
- Air conditioning parts sale
- My new ash-tray mounted boost gauge with video
- So.. today I locked my keys in my trunk
- Problem with DEPO's
- w203 c350 with six speed....opinions?
- Parts back in stock (LARGE INVENTORY)
- part number
- Thinking about purchasing a C55
- LOOKING FOR a GRILLE EMBLEM W203
- NewtoN13's UPDATES v.AzN Optics LED's, Plasti DIP
- 05 M.B. C240 4Matic, BATTERY ALTERNATOR, changed the alternator, resolved issue...BUT
- Where are serial numbers located on W203 Coupe Headlights?
- 4 choice for coilovers under 1000$
- How do I turn on my fog lights
- Has anyone bought the front suspension kits?
- Speed sensor replacement
- 2004 C240 Istrument Cluster Won't Cycle through
- Thinking about buying a 2001 320. I have ?'s
- Rear Differential Fluid change question
- MAF and steady high idle
- Exhuast tip size for dual diffuser
- FS: 2002 Mercedes C240
- New "lowered" strut/spring set up closest to stock ride quality?
- 06 c230 6 speed trans drain and fill
- Help installing aftermart wheels "2005 c230 sedan kompressor"
- AMG Bumper conversion. Answers needed on Parts!
- OEM front sport suspension
- 01 C320 jumps from side to side over small bumps
- Help With Strange Vibration/Idle Issue
- Wagon Photoshoot - A work in progress
- clk springs for w203
- Wiper fluid doesn't spray
- She us clogged up...somewhere
- C240 2002 , car radio urgent please
- DDMTUNING 35W HID Problem
- c320 Accelerates on its own - sticky throttle cables or TPS going bad?
- help with few codes p0620, p0600, p0020
- 05 M.B. C240 4Matic, BATTERY ALTERNATOR BRING TO SHOP red alarm came up on computer
- 05 c230k auto tranny problems
- help noise
- C32 Transmission Maintenance and Repair
- Antenna problem, PLEASE HELP!
- in the market for either my third w203 or a w209
- Fs: painted CF AMG trunk spoiler
- Private Sale: Declaring Gift or Purchase?
- dealer brake prices Q
- Lock/Unlock Signal Flashes
- Strange vibration when starting to accelerate
- FS: OEM Front rotors, pads, sensor
- FS- 2005 W203 Sport 5 spoke rims - $ 350.00
- C230 Kompressor taillights
- when set on auto ac turns off by itself
- 2003 C-230 ignition switch help!
- Would you buy this wing?
- Ebay Grill Star how to attach it??
- One small problem after Combo switch change...
- JBSPEED/Painted Trunk or Roof Spoiler $110 Shipped!!!
- M271: Help diagnosing problem (air/hose leak?)
- HELP?! C240 Subwoofer and Amp Installation!
- ?problem with my2004 c230k
- Another 2005 C230K SS Thread...
- PO120 Throttle/Pedal Position Sensor Circuit problem
- This noise is driving me nuts!!
- Anyone using Focal speakers in '07 or similar?
- Anyone know this Part number?...
- Anyone have a broken mirror?
- 19s on w203 luxury - need advice!
- Has anyone retrofitted a halo projector?
- Which coilovers go the lowest?
