View Full Version : CLK-Class (W209)
- CLK550 seat sliding while stopping
- audio install parts help
- CLK500 on dyno, some pre-run problems.
- WTB Steering Wheel 05 cabrio
- Car is gone
- CKS Quad Exhaust Experience?
- Cup Holder Part Number?
- ANY EXPERIENCE WITH THESE...
- CLK550 pushes 478 HP ( at pumpgas )
- Wind deflector for Mercedes CLK
- Looking for a cheap eurocharged TCU for a 722.6?
- 07 CLK550 sorted out then promptly wrecked
- Took my 06 CLK 350 on a road trip... smelled burny
- Clk 550 vossen cv3s
- Seatbelt presenter grinding noise
- 100 hp budget
- raising temperature!! please help!
- Thermostat change
- Rear annoying squeaks noise after new suspension upgrade
- Diff Service Questions...
- Problem with steering controls and aftermarket headunit
- E92 M3 FINALLY BEATEN.
- Need advice on spacers for 08 CLK 550 with stock 18" AMG rims
- Random acceleration?
- Muffler Delete?
- CLK350 outside trunk latch isn't working
- DIRECT BOLT ON UPGRADES
- CLK 200 Sports 2009
- Dual radiator fan assembly question :-)
- Command 2.0 speed sensitive audio volume
- cheapest place to buy LSD
- RED LEd SPIDER LIGHTS
- tire wear, what suspension part to replace?
- Protecting that vulnerable front clip
- Rear undercarriage protector?
- new struts
- 06' CLK 350 Convertible top stopped working
- Headlamp Range Adjust too low
- Opinions please
- Can't open top with key fob anymore...
- Malfunctions
- FS: Matte Grill and Facelift AMG front lip
- my recent tire experence..
- CLK 550...need computer reader Tampa bay area please
- finally got my AUX on my '04 clk on my mercedes-benz radio :D
- CLK320 and C230
- FS: RennTech Airbox M113/M112 V8
- coolant issue
- 2004 w209 CLK 320, H&R spacers xx556659, bolts & more
- Need a good shop in IE
- My New Stable mate
- 2004 CLK 500 A/C Help
- W209 Dome Light Unit: Aircon sensor fan on PC board
- scratched my front wheel...
- What the heck is this?
- Soft top unglued
- clk 550 koni yellow shocks part number
- Air Quality Sensor - what does it do?
- I designed a bracelet
- Aux input not working even after cable replacement
- LF: clk pre-facelift carlsson cf lip 03-06
- Canbus Ballast still flickering?
- Help suspension issue, pothole pulls!
- CD Changer: Removal of stuck CD
- 04 CLK320 wiper, seat belt extender/retractor issue.
- Radiator
- brake wear light on/off/on/off??
- Ambient Temp Sensor always shows a higher temp
- CD Player
- TRANSMISSION VALVE BODY ISSUES - CLK500
- Camber bolts, 2 or 4?
- Spark Plugs
- NOS on CLK550?
- Cheap bluetooth solution and dashcam hardwire
- Which spring pads when I put in Eibachs
- I want to downgrade my wheels
- 2003 CLK500 transmission rebuild $4500... Too high?
- CLK55 parts on a CLK500
- W209 CLK55 Intsrument cluster for sale
- different between the dust filter and carbin filter
- P0104 code: Need help!
- P0453 code
- ATF
- How do I replace my serpentine belt?
- Thinking of Buying CLK 500, Have a few questions.
- vacation car rental...
- Steering Angle Sensor
- Center Console Flashing When Headlamps are on?
- Clk 240 help (ashtray and headrest)
- Finally got a chance for some decent pics
- Clk55 Diffuser
- Does my sucky sucks at sucking?
- w204 c63 steering wheel and air bag on clk 350? FITMENT ?'s
- Halogen to Xenon
- Is there a "Bra"for my CLK?
- Non-AMG Prefacelift to Post AMG Bumper
- New Dual Exhaust Just Finished!!
- TX to WA W209
- Mounts
- kompressor for clk320 ? does it fit?
- LED Tail lights
- Timing Chain
- is it possible to swap a 2008 control system into a 2005 clk 500
- Passenger Power Seat not working.
- Do I have to do both front and back sway bars at the same time?
- My new Exhaust setup
- Could Use Some Help 2002 CLK320 AUTO
- Coolant leak in CLK 500
- I should have got this!!
- Air Pressure
- WTB Stone interior door panel
- New Owner, and now to start the mods!
- FS Mercedes Steering Wheel
- New tie rod ends
- anyone like the older tails better? Also, need mudflaps
- 18x8.5 CLS63 style reps $549 NEW from PowerWheels Pro
- W209 various issues
- CLK63 Bumper Hella 90mm Retrofit (pics)
- single sided diffuser!
- I need help on my command center. There is no sound.
- Help with first oil change...PLEASE
- Finally the clk threw a code
- Maxton Design Front Bumper 2004 CLK
- Someone Check vin for balance shaft please?
- Replacing convertible rear partition strut cylinders
- Thoughts on 3rd Party Extended Warranty
- Which company should I go through for an ECU tune?
- 2011 navi cd for clk 550
- Rear view mirror dis-assembly
- Headlight resoration
- Correct wheel?
- Purchase Advice: Two competitors! Help!
- New to the club
- Very subtle shaking on clk550
- need new sneakers; can I get some tire opinions?
- W211 E63 Wheels???
- Tired of looking at a dull and lifeless dash?
- Want to buy V60 puck PN B67875856
- What Navigation Radio fits 2005 CLK500
- Need Help, cylinder missfire!
- driver side mirror housing loose....
- lowering a clk500 cabriolet
- I am selling my used two custom enclosures (L&R) made from fiberglass
- LED Mirror Covers
- I want to buy a Front Bumper
- My clk 350 2006 !
- 2009 clk 550 navi command question
- Close Partition message
- 722.9 Transmission Service
- FLUIDS
- TIRES
- OEM Bluetooth integration
- Can I use 5W30 Synthetic Oil in my 2004 CLK500
- Need help to remove rear parcel shelf, W209 coupe
- Just dropped a headliner
- Front lower control arm leak
- Air Cleaner R & R fixes problem???
- A Truly Close Call!
- Basic Questions for 2004 CLK500
- Replacing speaker grill cover on 2006 CLK320 drivers door
- side window leaks 2007 350 CLK cab
- Question on behalf of a CLK500 owner...
- Mercedes gets crushed by a gigantic tractor
- Misfiring - Codes P0300, 302, 303, 304
- New guy buys clk 500.
- ESP inoperative after getting car lowered
- CLK350 sold, CLK550 purchased.....
- side mirror back-up feature...
- couple of small parts: are they even available on their own?
- Interior Temp Sensor replacement...$$$$?
- Light problems.. Clk
- Leather shift boot replaceable?
- *Picture request* Silver CLK 500 with carbon fiber hood
- DB Carbon interior & exterior Group Buy entire MB product line
- 245/40R17 all the way around?
- Switching spare tire well to 55 for quad - question
- 2005 320clk - seats wont adjust
- Putting the spare tire back 2005 CLK320
- FRONT BUMPER PART
- Weird issues that seem to be getting worse :-/
- CLK-500 Xenon lights (2003)
- NAVRGB-MBCIRC install
- Anyone want to sell there stock lug bolts?
- auto level hid acting up
- What are the measurements of the center caps on these wheels?
- FS: BRAND NEW W209 CLK550 CF Front Lip $250
- Car engine died at stop light, dash lit up like christmas tree
- CLK 500 Exhaust ideas?
- Subwoofe size???
- Rough idle after cam plug change
- CLK500 project with geniun AMG bodykit and AMG exhaust.
- Removing factory iPod adaptor??
- LED Trunk Lighting
- My camera install
- Light interior (cream?) - what to do about dirty seatbelts
- CEL on, off, on, off...
- quick help VOSSEN craigslist post need info
- Bad low beam igniter
- T-bone collision
- Selling my 2008 CLK350
- Dumb question about Youtube videos in posts
- Replace the hear Bose woofer for other brand
- Oil Change???
- seat problem
- mBrace Problem - Weird Latitude/Longitude
- WTB front right wheel for 2008 CLK350
- Passenger side window regulator
- Convertible flaps won't fully close
- Can someone tell me Will These Wheels Fit my clk550?
- Windshield change causes louder engine from cabin?
- New Member here
- Electrical connection to sway bar?
- bleeding brakes
- brakeperformance.com
- production figures for CLK's
- WANTED: rear bumper in black
- Best milage you have gotten in your CLK550
- coilovers talk??????
- Will CLK63 Bumper fit CLK550????
- Anyone Know the Settings to Open Convertible Top from Outside
- SoCal vert owners who park outside...
- OBD-11 Diagnostic Tool
- NEWBIE NEEDS HELP!!! Convertible Top wont work
- PLEASE HELP!!! AMG Bumper fitting question
- CLK-500 RennTech Airbox
- Phone and NAV volume
- how to adjust brake drag
- 2006 CLK350 Error Code P0128
- W209 facelift Command
- Help Please, Roof wont work!!
- CLK500 Idle Headaches
- radio wire diagram 2004 clk 320
- UHI control module part number needed
- Exhibition of speed ticket.. HELP
- FS : An OEM Shift knob w boot + Base of CLK550-08
- Set up for clk500 rims wheels lowering springs kit
- OT - Desperate
- Coilovers - rough ride on stock rims
- DIY: W209 fix for creaky sway bar bushings (w/pics)
- Intro, and suggestions needed.
- Just Got An 08 CLK550
- Questions about replacement R1Concept rotors
- 3WD: Prior Design Black Edition Widebody
- w209 CLK LED aftermarket lights
- Replacing sway bar bushings?
- CLK 500 Hard Start 1st time in each day...
- Prior Design CLK Widebody Kit
- Clk 63 caliper mounting holes measurements?
- Posting large pics in text?
- 2003 CLK 500 Radio Replacement
