- REALLY need some help guys! Differential?
- Retrofitted Command Help Please
- CLK320 trouble code P2067
- CLK 320 AC Control Panel
- Safe to buy a CLK430 with 200,000 miles?
- Help needed please
- C32-Clk55 brakes.
- HELP on idle revs are jumping from 200 to 3000
- HID ballast removal
- CLK 320 VIN Location??
- Front Bumper Removal
- CLK55 AMG W208 Quad Exhaust System with Diffuser
- K&N
- 1999 clk 320 running bad
- WIS DVDs
- Water leaking in footwell, W208 Convertible
- Top pump problem
- Buzzing noise when accelerating
- Brabus parts for the 208
- 2001 CLK320 Headliner Trim
- Akebono brake pads
- Red seat belts?
- Brake caliper and heat shield painting
- What size Allen wrench
- rear sway bar install
- WTB Front Camber Kit
- Radio Code Needed CLK320 99
- This is probably the most expensive and disireable number plate in the world.!!
- W208 CLK 230 Vibrations when Accelerating
- First time MB owner, 2002 CLK 430 Convertible. Some questions.
- Should alignment have compensated for larger 18" rims/tires ?
- New Junk in wifes Trunk pic *What to stick in my wife's gaping hole*
- Looking for Repair Manual w208
- Rear flex disc. Need info., Replaced front OK, how replace rear ???
- CLK W208 roof dont go down, please help
- Clk 320
- 2000 CLK320 Rattling Noise 58K miles
- What parts does the AMG front bumper consist of?
- FAB DESIGN F63RS - (Based on Mersedes-Benz CL63 AMG)
- Either replace or eliminate the resinators.
- 98 clk320 tune up
- M113 V8 Engine valve cover gasket for sale. New!
- gear selector problem
- drag link torque specs?
- Cabriolet Owners - Myth or Fact: All Cabriolets eventually develop a shimmy at 60MPH?
- WTB: Stock exhaust system
- Rear sway bar install question
- Door speaker
- removing canvas
- question aboutbkmac front camber kit
- WTB: oem stock headlight
- Custom rear bumper up for grabs
- CLK 230 20001 audio swap?
- HALO PROJECTOR LIGHTS
- decatted 320?
- CLK 430
- Newbie Cruise control Option
- clk 320 door stops
- revenge of the mouse:electrical
- CLk (w208) windscreen
- alternator question
- does your side mirrors electronically fold?
- WTB: AMG STYLE FRONT BUMPER
- FS: FULL SUSPENSION BILSTEIN & H&R, PROJECTOR HEADLIGHT HID, 5 STAR GRILL
- Pipe size for resonator delete?
- pitman arm and idler arm VERY IMPORTANT NEED QUICK REPLY!!
- agonising over mags
- Best performance gain modifications? CLK430
- '02 cabriolet pse vacuum pump ???
- REAL CARBON FIBER ROOF SPOILER FOR SALE
- Cats Rattling again
- What options are standard on the clk? Need some info.
- Mirror motor question.
- SprintBooster
- JBSPEED/Emblems & Pedals
- PO141 Sensor Heater Circuit Malfunction Bank (1) Sensor (2)
- Faster Transmission Gear Changes
- Custom projector headlights for sale
- Brake pads to minimize brake dust?
- Tokyo Custom Car Show
- Lorinser exhaust, 230k
- Intermittant Rough Idle Problem...????
- 1999 CLK320 - Which Oil
- Cabriolet Roof problem
- What is minimum thickness of w208 rotor?
- Vibration driving me nuts all speeds
- fuse help
- Creaking coming from rear control/A arms...
- tomcat07
- Climate control panel bulb size?
- Whining noise
- Relay hardness installation, help me
- L STYLE CARBON FIBER ROOF SPOILER FOR SALE
- Right mirror when backing up... clicks
- any have speaker bracket?
- radio code for 2001 CLK430
- w208 CLK430 swap with w211 E500
- Lowered CLK, but still way to high
- Xenon White HID 6500K H1 7.5W High Power LED Bulbs Day Driving Fog Lights?
- P0170 and P173 - blinking fuel warning light?
- speaker grill needed.
- Please help me order wheels for my W208
- Replacing City-Light bulbs?
- Right Side Mirror Lens part number needed for W208
- Electrical issues after disconnecting battery on 2000 CLK430
- clk 320 roof wont work
- FS: General Exclaim Tires 225/35/19 & 265/30/19 - $400
- ESP\BAS\ABS Transmission Limp mode
- 5.4 swap!
- 02CLK320 Misc. Parts Swapping - Recommendations PLZ
- Help!!!!!! Clk trouble!!!!!!! Help!!!!!!
- 430 Compared to CLK55
- Should I buy this Navigation System?
- SIDE SKIRTS
- Fog light connector for H1 bulb website inside
- IC MALFUNCTION Display Defective Visit Workshop! W208
- Haven't posted in ages. Purchasing w208 AMG Advice
- Replaced turn signal switch...got a couple questions
- Benz dealer diagnosed my car, are they rite?
- Avantgarde trim package - color-key dark bronze chrome trim?
- Indy told me $800 to replace condenser & drier ???
- 30000K BLUE HID HEALIGHTS
- Updating side skirts?
- Task: Transform a "normal boring" CLK to a hot one
- Slightly Used front tires and stock wheels
- Supersprint Exhaust
- So, have never heard of such a thing--a hot water pump?
- custom headlights
- Transmission Issue
- Other models w/ interchangeable wheels as the W208?
- Out of curiosity ! I need an explanation ( fogs lights)
- Paranoid: What precautions Re. Conv. top failure ?
- 2002 CLK55 AMG Front Bumper Valence Spine for Sale
- Fog light connector corroded help
- Boot Locked Jammed - One Method
- AC Issue: Weird Codes...
- [Showroom Motorsports] D2Forged NY Auto Show Promotion!!!
- Popping noise from DS front brakes while turning?
- 2001 CLK430 AMG, what to look for during initial inspection
- W208 Cab - Can't get into trunk. Whats the Way in?
- HID installation steps/pictures for CLK430 (halogen)?
- Anybody have this problem wit ESP,ABS....
- INSTRUMENT CLUSTER
- 20's on the clk
- clk 430 stock wheels
- MOD List - Update
- Hella Super Horns now in stock
- Stuttering with no power, choking?
- Front Camber kit needed
- looking for
- Antenna help Newbie 2000 clk
- Having Instrument Cluster Issues
- pixel fixed and needles as well
- Missing Auto transmission dip stick?
- Strange pulsing when pressing brake pedal at low speeds
- swaybar bushing
- FS: Stock trunk 6 disc cd changer
- Don Nguyen | Clear headlight film protection - Prevent rock chips/cracks
- W208 Manifold Confusion
- 99 CLK 430 Oil build up
- W208 Cab - Location of Soft Top Micro Switches & Relays
- Restoration of CLK 230 W208 Convertable
- Price for scrap exhaust pieces??
- Need help with car shaking , CEL light on
- can someone please help and check their fuel relay...
- Chrome 17" AMG wheels
- Sending my cluster instrument
- HELP! new bumper
- Couple of Vipclk one offs available
- New Becker Grand Prix 7990 for my 2000 clk430
- AC help.
- Warning Lamp indicator grrrr
- Coilover
- CLK430 Cab... Got Newbie ????'s
- Eurocharged Calgary / Edmonton tune day
- Any recomendations for a new battery?
- Qaiffe Differential - V6 CLK320
- EC Button Stuck on after freo leak
- Cabriolet Roof Not Working After Flat Battery
- emergency question/help
- Pampering the car ready for Summer !
- Is it safe to wash the engine? and where/how?
- Shocks and Axle Replacement Help Plz
- 99 CLk 430 Altenator
- Replacement key housing off eBay
- Air Conditioner
- fs: SLS Carbon Fiber Shifter
- PLEASE i need help, having problems w/ CLK
- clk320 part name
- Cars got her Summer Sandles back on.
- Change back to original wheels
- WANTED 2002 CLK55 Cab
- Trunk Light Issue : Rear Fuse F5 Keeps Blowing
- Drivers seat stuck
- Interesting outcome with seafoam
- CLK 430 Front Bumper Cover Can be Repaired
- W208 Subwoofer Location
- Bodyplug missing or drain - interior wheel well?
- Eurocharged Montreal/Ottawa/Quebec tune day
- FS: 2002 Mercedes CLK430 - LOW MILES - Black/Ash - Downers Grove, IL
- Battery Specs.
- to Keep the 208 or sell it!!
- 2006 MB CLK350 vs 2006 BMW 325i
- V6 Headers
- I feel a knock or tap through my steering wheel?
- Power Seat Broken
- Instructional: Installing Shocks 2000 430CLK Cabriolet
- CLK Wheel Question
- JBSPEED/AMG & Brabus Style AT Pedals $65 Shipped!!!
- removing power steering reservoir from clk 430
- Fog Light Bulb Replacement
- Mystery part
- for sale 430 chrome exhaust tip
- OBX Headers
- Car stutters under acceleration, sometimes dies
- w208 spoiler lip?
- side marker lights
- Another Source For Braided Steel Brake Lines
- Falling appart
- Upgrading Convertible Subwoofer
- oil leak
- Instrument Cluster Change
- [Showroom Motorsports] Gauging Interest for Painted OEM Replacement Parts
- Volume control out of control!
- exhaust
- clk 430 no power after a hard accelaration, stop turn off and back to normal
- EGR valve
- Dash doesn't read gear, car no longer shifts gear
- trunk lip
- JBSPEED/Hood & Trunk Emblems Great Selection!!
- stripped threads on hub
- 1999 clk 320 Conv Top problems
- Bent Rim
- 2000 clk 320
- Vibration when first start in park, possible transmission mounts?
- spring pads question
- Stock AMP and Rear deck speakers FS!
- Coilover options for 230k
- Advice on tires & exhaust system for '01 CLK 55
- Instructional: Installing front brake pads.
- Seal between roof top and door broken.
- finally put on my lorinser
- WTB D comand disc for region 1
- Tires
- Tell me what you would pay for my high mileage CLK!
- Miscellaneous CLK Parts
- Got a spring compressor?
- Starts, stall, restarts and then runs fine?
- Can anyone identify these rims?
- throttle reset after Flash tune?
