- FS: R170 OEM Wind Screen
- Red 1998 Mercedes SLK230 @ Isringhausen Imports (Low Miles)
- Repairing front Bumper on R170 SLK
- SLK320 Sold - Part Out
- newbie to the benz world//CD CHANGER HELP NEEDED PLEASE
- SLK 230 Custom Rims
- r170 telephone aftermarket options
- side marker lenses
- Eurocharged Montreal/Ottawa/Quebec tune day
- Brabus CF interior kit anyone?
- windscreen oem
- MAF
- Heat only
- SLK230K alternator removal acc belt tension
- Car stutters under acceleration, sometimes dies
- Serpentine Belt Diagrams
- SLK230 Shifter gate cover
- leutgeb
- leutgeb
- SOS system
- leather hinge cover repair
- What else can I do? (Mods)
- SLK230 idles up then down over/over - help
- Ch Eng Lt on and running on 3 cyls and tranny chugging
- chevy 4.8 swap
- Roof question - can it be operated manually?
- Rear cover extension doesn't move when retracting roof
- 2001 SLK230 w/ P0243 & P0410 Codes - Still Cannot Fix! HELP!
- What to look for ? WTB a SLK
- I need Engine Control Module 1998 SLK230
- Need Ideas
- 99 SLK230 with 172K for a Toy - Price? Problems?
- ECU Tuning Group | Mercedes Benz SLK230k ECU Upgrade
- Removal of headlamp unit offside for my SLK 320
- steering noise
- Would you buy an R170 SLK 6-speed in today's age?
- Wiring for sub woofer amp on SLK 320 (R170)?
- Roof Won't Open.....no movement
- SHIFTER MECHANISM
- Looking for Front AMG Sport Package Bumper 2001 SLK230
- 98 slk power top
- Write-up: How to remove & replace dash/instrument cluster lights
- Wont turnover!
- Red SLK needed for MB Classic Center photo shoot
- slk320 100k maintenance
- Buying 2003 SLK 230
- SLK320: P0141, P0136, P0410
- New to forums
- Stuck in 3rd
- SLK questions
- FS: BRAND NEW Front KMAC bushing kit
- Dyno'ed my SLK before and after tuning.
- A friend of mine needs help with her 230 Kompressor...
- buying a 1998 slk
- Replacing brake light switch
- What Makes An AMG
- Crank position sensor location/pictures
- Whistle noise from fresh air flap
- Replacing the Alternator
- SLK 230 1998 - Mass Air Flow replaced but same loss of power one month later.
- communication failure on slk 230k
- Anyone here DIY their head gasket?
- 2001 SLK320 Radiator Fan won't turn on
- M111.957 lower engine leak
- Pulley install on an SLK 230
- c230 wheels on slk
- Phone turns on and off repeatedly with key off
- 99' Slk230 with 203miles
- FS: AMG Rims off CLK (currently on C coupe)
- Selling my SLK32 AMG
- R170 SLK230 Sport Lower Mesh Grill
- 1998 slk
- PLEASE HELP!! 1998 Mercedes SLK 230
- Tyres/Rims/Suspension/Brakes
- What are some major issue that I should be concern about on the SLK230?
- Throttle lag and maf cleaning
- SLK 230, very sloppy :(
- DTM Style Leather Steering Wheel (170)
- SLK (R170) Interior Light / Dome Light anyone?
- R170 Handling Issue(Tramlining)
- SLK (R170) Modifications
- Wrong Drag Link?
- Stereo question
- Which one too buy ?
- anyone have a custom intake for there slk230 kompressor?
- Just changed my brakes and I have a few questions.
- Fog lights come on after I lock car HELP
- Looking for a SmartTop module for my slk32
- slk230 Drivers Window and roof not working
- Top issues (Leak and stops in mid operation)
- Illuminated shift knobs anyone?
- SLK230 KOMPRESSOR 2001
- 1999 Mercedes Benz SLK230K Part out
- both brake lights, cruise not working
- slk230 kompressor power loss (no guts)
- key wont move help!!!!
- NO START
- radio
- SLK32 Part Out Sale
- Dome light stays ON
- SLK(170) DTM Leather Steering Wheel
- Immobilizer keys do not respond
- SLK 230 (R170)Alarm goes off intermittently!!
- I need a HELP
- No Start!!! nT_Tn
- Fuse box pocation
- Power locks doesnt work
- SLK230 R170 2001 side window replacement
- DIY for Throttle (Gas Pedal) on 2001 SLK320?
- Brembo/MB four piston caliper anyone?
- LYC's - Blue 02 SLK Photoshoot :)
- whining noise when the heater/AC is turned on???
- Likely buying an SLK 0n Thursday...
- alarm horn not working....'98 SLK230
- First Time buyer, SLK230
- part #s for breather/vacuum hoses?
- Question in regards to Kleemann boost pulley
- manual gear shift knob and radio
- Just bought a Christmas gift for myself
- SLK 2003 ASB/ESP and Limp Home Mode
- It is Tranny time - what ATF to use?
- CLK55 Engine for sale
- Not cranking...
- 55K engine swap
- Painted Angel Eyes?
- Head Unit
- p0440
- Time to change tires..!
- Removal of the grill
- My Wheels, they are ruined!
- jbuss05761
- I FINALLY GOT ONE!!!!
- Good shops in Houston TX?
- No Fuel & fog lamps stay on....
- MY CAR WONT ACCELERATE !!
- Are the left and right motor mounts the same?
- WANTED: Electronic Selector Module, SLK
- SLK230 - cranks but wont start
- Difference between 1998-2000 and 2001-2004 SLK 230?
- What is this? Picture
- SLK Vario top issues -How to open manually
- M113 V8 into R170 SLK
- SLK 99 - Convertable Hydraulic Cylinder problems
- No power to OBDII underdash connector
- What is that "POP" sound??
- Cruise Control issues on 2000 slk 230
- Only Right Side Lights Flash when Alarm is armed
- Cam Adj Recall
- 99 SLK 230 Roof leaking oil - stopped working
- 98 SLK 320 Not getting 14 volts at battery
- SLK Spring Rods
- Recommended online paint supplier?
- Roof problems
- Is it that difficult to find a manual???
- ECU Reprogram or used IFZ enable?
- 98 slk 230 help!!!!!
- Need help finding Becker BE3302 radio button
- NO VOLUME
- automatic transmissions
- Wiring problem with ABS pump
- New Russian site...
- Transmission problem. Help!
- slk r170 h/lights
- Questions about the Convertible Top (and Brakes)
- 99 slk230 on board diagnostic
- oil leak from camshaft solenoid?
- hydraulic leak in convertible roof
- Just got an crappy barn find money pit. SLK
- CROSSFIRE SRT6 POWERTRAIN VIBRATIONS
- A "Signal" of Trouble to Come?
- BAS ASR light
- This Merc rides dirty!!!
- Two tone (top/body) SLKs..?
- SLK320 Crankshaft Sensor help
- Comparison question between models/transmissions
- cold hard start and shocks
- AUX in R170?
- 1999 SLK 320 bad gas mileage until battery reset
- SLK cutting out, electrical problem?
- WTB: ASP Pully Kit for 98-00 SLK230
- Passenger air bag
- SLK heater controls malfunction
- Lubing SLK roof..?
- SLK 320 Top Speed
- 2001 slk 230 bas/esp light on but system working
- BAS ESP / CHECK ENGINE car cutting out
- Engine not cranking..!
- hood shock
- April 17, 2010 Northern California SLK Enthusiasts Meet & Drive
- Transmission whine 1st thing in morning
- ESP/BAS warning light intermittent
- WTB driverside visor/vanity
- Very odd fuel consumption
- completely dead battery. Questions.
- 230k M111 Engine. Poor Fuel Consumption - very bad
- No power to radio - only pulling 2volts check via connector A
- 1999 slk 230 many codes..
- Cassette Adapter for iPod works pretty good
- Car Phone Tray Replacement
- Hi Newbie to forum - Performance
- Hello to all
- SLK Supercharger/Engine Upgrades
- Passenger door mirror oddness
- Driver's side heated seat not working...?
- Veloce Performance Valentine's Day Special...
- 2/20/10 Northern California SLK Enthusiasts Meet & Drive
- Antenna Broke in CarWash...HELP!!!!!!
- WAAAAy beyond peeling paint--how about crumbling lower dash panels
- Crumbling lower dash panels
- 18 inch WHEELS
- 18 inch SL 55 wheels
- Windshield Washers Problem
- Car died in parkway traffic
- Engine hood piston pooped
- Transmission Fluid - how to check
- Is it just me or is the SLK320 throttle respond lacks
- tunning & re map
- VELOCE PERFORMANCE NEW YEARS EVENT!
- slk 2001 230
- slk transmition
- slk air con
- Service Campaign
- Coolant Drain/Exchange
- Torque Converter Drain Plug
- slk 230 r170 Passenger Side Mirror detatched from housing
- 2001 SLK230 Supercharger
- '03 SLK 200 OEM Engine parts
- Looking to purchase 2000 slk230, cpl of questions
- Removing Engine Cover
- SLK 230 heater control bulbs.
- Tire size
- V8 conversion with pics and video
- slk230 top operation for dummies
- QuickTime of 11/21/09 No. CA SLK Meet/Drive
- spare key for 1997 SLK needed
- Transmission problem?
- Holiday Special - Group Buy - What Are You Interested In?
- New Sponsor Introduction - The Workshop MB
- Water on carpet
- For Sale AMG Exhaust off a 2003 SLK32 AMG!!
- November 21, 2009 Northern California SLK Enthusiasts Meet & Drive
- lorinser complete body kit
- surging RPM
- Help removing center panel
- Fair price for 2000 SLK
- AC vacuum lines behind glovebox
- High-Pitched squeel in cabin
- SLK MAF issue?
- V8 conversion almost finished
- Need Info on 98 SLK 230
