Sign in using an external account
| Mercedes Tech Talk Discuss general technical questions and issues about your Mercedes-Benz. Moderated by a certified MB Tech. Sponsored by : Pelican Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Drives: 97 sl320
$5 part - $800 Mirror?
#2 |
Drives: Debadged 6-Speed '05 C320 Sports Coupe
Two-part epoxy. Ensure the spring is not working the bond loose, until after the epoxy is fully cured.
#3 |
When my mirror popped on the inside on my E320, I bought a replacement from Ebay, about $129 brand new. Just had to get it painted, well below $800.
A suggestion to do the same...the epoxy will work as well also.
__________________
CLS500 |AMG Package | Premium Package | Lighting Package | Entertainment Package | iPod Kit | Keyless Go | Parktronic | Distronic | Hands Free Communication | Bluetooth | Trunk Closer | Voice Command R500 | Premium Package | Lighting Package | Entertainment Package | Parktronic | Hands Free Communication | Bluetooth | Chrome Package | On 20's E320 | On Chrome 16's |
#4 |
Drives: 2003 S500, 03 C240, 03 E320, 03 tahoe
man thats a good find!
Quote:
#5 |
Drives: 97 sl320
I looked closer at the bezel and its got a part number and an ABS PC stamp so I'll know which epoxy to get. I doubt if the part number gets me anywhere. It's a shame that a known weak link on this simple and easy to replace piece costs the everyday customer $800 to fix by having to replace the entire assembly. And a little intimidating for the diy crowd, it looks like there is maybe one or two shots at doing it correctly.
#6 |
The pale yellow segments were bonded back together, w/ two-part epoxy, in addition to the broken part on my ABS console cover. It's held up well for almost a year / 25K miles without problems, as shown in this topic.
#7 |
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
You
can pick up the whole mirror at several east and west coast wrecking yards.
ohlord
#8 |
Drives: 03 E500 and Corvette
Quote:
What is the part #? |
#9 |
Drives: 97 sl320
#10 |
Whenever I open an interior trim assembly I lubricate the clips w/ white lithium grease to make subsequent actions better w/ less risk of breakage.
#11 |
Drives: 221.122 & 212.025 & 204.089
This part must have been available at some point of time but does not seem to be any more. Instead there only seems to be a parts kit available from MB. Unless it is built after 08/96 when it would have 210 mirrors, you could consider buying those if you get them cheap.
http://www.detali.ru/cat/oem_mb2.asp...SGR=105&SGN=05 |
#12 |
Drives: 97 sl320
[QUOTE=Diesel Benz;2803458]This part must have been available at some point of time but does not seem to be any more. Instead there only seems to be a parts kit available from MB. Unless it is built after 08/96 when it would have 210 mirrors, you could consider buying those if you get them cheap.
How would I mount them to the inside of the windshield?
#13 |
Drives: 97 sl320
I did a glue job on the bezel. Hopefully, the job will turn out to be strong enough to hold the retaining clips. I'll post pictures of how I did it (or how not to do it) after the weekend.
#14 |
Drives: 97 sl320
After configuring several ways to apply some kind of plastic to replace the original spring retaining pieces, I decided to use existing plastic parts from some other plastic object. I used a Dremel tool to cut and shape the parts.
First I found a nice looking piece of an old monitor base, also made of ABS; there was only one these shapes available. ![]() ![]() I cut the second piece out of a 5 1/2 inch computer case bay cover. ![]() I notched each piece to fit the reinforcements on the mirror bezel. Here is the dry fit of the first one: ![]() I chose Plastic Welder epoxy by Devcon which works with ABS. I called Devcon customer service and they recommended to clean all surfaces with alcohol and claimed the bonded parts should be stronger than the original. I then sanded all mating surfaces and glued them in. ![]() ![]() ![]() A rough and beastly looking job, but looks don't count for additional strength. I reassembled the mirror, the bond seems strong as a rock and the mirror functions as new: ![]() ![]() ![]() ![]() $800 saved! |
#15 |
Drives: 97 sl320
This bad boy is still holding up.
#16 |
Drives: CLK63 Black Series
Awesome fix! It's a shame that most dealers won't take the time to craft repairs like this anymore. If this problem happened to anyone else the old mirror would be in the garbage can and $800 would be wasted.
__________________
2012 VW Golf R 1999 Chevrolet Corvette 1989 BMW 325i 2002 GSX-R 750 2008 Mercedes-Benz CLK63 AMG Black Series (sold) 2004 Mercedes-Benz CLK500 (sold) |
#17 |
Drives: 2005 SL55 AMG, 1970 Dodge Charger 440, 1986 Porsche 930S, 1996 Porsche 993tt
Great job!!!
Now you just saved $800!
__________________
2005 SL55 AMG Powerchip Group, VRP short headers , K&N filters, PTE thermostat, AMS pulley, K-Mac. 360 Forged wheels-Spec 5ive, Reus Audio |
#18 |
Drives: 97 sl320
If they would actually be creative and fix it the way I did, I had to see how many hours they would bill. What bothers me is that this is a part that is known to break; MB should have an easy to glue in repair kit available at the parts counter and if service fixes it, maybe one hour labor and $10 for the kit.
#19 |
Drives: 97 sl320
#20 |
Drives: 08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
#21 |
Drives: '07 GL320CDI
It's so disappointing to read all this conjecture and speculation as regards parts availalbity when MBUSA make the entire USA parts system available for free to anyone in the USA.
Subscribe and look it up. Door mirrors are in the doors section. http://epc.startekinfo.com
__________________
Kent Christensen Albuquerque '07 GL320CDI |
#22 | |
Drives: 97 sl320
Quote:
#23 |
Drives: 97 sl320
#24 |
Drives: G350 Bluetec
I'm going to commission you to fix Gwagen inner door handles! Double bubble glue, who knew?
| Tags |
| 0635, 129, 1298110635, 5, 800, 811, assembly, benz, clk, mercedes, mirror, mirrors, part, pc, saved, sl320 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
