eccentric bolt for front axle alingment
W212 E63, Audi R8 4.2, Panamera S, Range Rover Sport GT
anyone know where this bolt is located, and how it works? I need to adjust the camber on one side of a customer's car (one side has greater camber than other, and dealership will not touch it). It is a 2002 CLK430.
Thanks!
Thanks!
Originally posted by nov0798
you will probably need to install camber bolts
Originally posted by awiner
The bolts DO NOT come insallted from the factory. You will need to buy them at your dealers service dept.
Does anyone have the answer to my question?
98 E430
if it's installed, its in the same location as the stock bolts they are on tthe lower a-arm that bolts to the body. You losen them up, and you turn them. You are going to need alignment machine to do it correctly.
