Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Mercedes Tech Talk
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-03-2012, 04:03 AM   #1
Drives: mercedes benz cl600
shifter stuck in park cl600 need help
okay a week ago my shifter was having a problem getting out of park, one morning i found it completely stuck in the park position and no matter what i did i couldn't get it. I have read that its a plastic piece that breaks and gets the shifter stuck in park and that one way to get it out of park is to hit it on top of it with a mallet. Im pretty good with cars so i have decide to fix this problem on my own. I have tried many time to get it out of park so that i can remove the center console by hitting it on top of it with a mallet but it wont budge. i have found a pin that i think by removing it will release the shifter but im not sure and i dont want to mess anything else up. Can somebody please tell me is there anyother way to get it out of park and is this pin the key to it.
To remove this ad, register today or login if you already are registered!
armeng83 is offline   Reply With Quote
Old 02-03-2012, 09:14 AM   #2
Drives: 97 S420
Wow!, I don't think beating it to death with a mallet will fix your problem, but it may stetch your repair bill a page or two.
First off, what year is your vehicle?
Second, it may be that you have a brake pedal switch that is acting up. (If your benz is like mine, it will have it.)
Get more info before it costs you some major money!
Dan Morgan is offline   Reply With Quote
Old 02-03-2012, 04:18 PM   #3
redcoupe's Avatar
Drives: 11 ML350
The only thing you can do is pull the shifter back and beat it with a hammer. Somtimes it takes a couple hits. The pin your seeing in front, is a lock pin, it keeps the shifter assembly from being removed while the shifter is in park.
redcoupe is offline   Reply With Quote
Old 02-03-2012, 04:23 PM   #4
Drives: cl600
also check your brake lights to make sure they are working. if they're not, replacing the brake switch may solve your problem.
biker349 is offline   Reply With Quote
Old 02-04-2012, 04:48 AM   #5
i have check the break light and it is working and the car is a 2001 cl600
Old 02-04-2012, 08:21 PM   #6
Drives: 1998 VW GTI
Just because the brake lights work doesn't mean the switch is good. These switches aren't just a two wire switch for brake lights. They are usually have a separate circuit that goes to the shifter control module to release the park lock. The brake light portion of the switch may still be good but the portion going to the shifter could still be faulty.
DerekLMartin is offline   Reply With Quote
Old 02-05-2012, 07:27 AM   #7
Melk63's Avatar
Drives: CL600 V12 biturbo
Hi, You can do the job yourself. I have. First read the posts in W215 S-class forum in general How-to section to see how the job is done. The only difference with W215 CL600 is removal of the centre console. There is a recent thread in W215 CL section where I explained how to remove the centre console in a W215. The job should take 2-5 hours depending on your DIY capability. No special tools needed.
Mel.
Melk63 is offline   Reply With Quote
Old 02-06-2012, 02:51 AM   #8
i know the process to remove the center console and how to get the shifter out and to fix it, the only thing is i cant get the shifter out of park to slide the center console out, that's my problem. is there another way to get the console out without putting into drive.
Old 02-06-2012, 06:43 PM   #9
Drives: cl600
only way i've read is to pound the top of the shifter while pulling back. remove shift knob first.
Old 02-07-2012, 02:23 AM   #10
how many times do i have to say this, i have tried that but it wont budge people is there another way or do i result in sawing off the handle
Old 02-07-2012, 05:02 PM   #11
Melk63's Avatar
When I did mine, I had already managed to move the shifter out of park by wiggling the lever back and forth violently quite a few times. That allowed the centre armrest to move completely out of the way. If you cannot get the shifter out of park, you may still go ahead and try to get the centre armrest freed up by taking all the holding screws out. If you then lift the rear end of the armrest and reach underneath and disconnect all the wires you may be able to move the armrest out of the way far enough to get to the gear selector box. It may be worth a try this way if you have not tried it.
Mel.
Old 02-09-2012, 01:55 AM   #12
Drives: benz master tech.
I am a mercedes technician, if you cant get it by tapping it with a hammer you need to bend the shifter rod, remove the shifter knob and place a jack handle over the rod and bend it backwards,this will allow you to get it apart. As far as being able to do this yourself, you need an SDS to remove transport protection and activate the ESM which will need to be performed by a shop with adequete equipment.
brewmastr is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
01, 600, benz, brake, cl, cl600, drive, gear, gearshift, light, mercedes, move, park, shift, shifter, stuck, switch, w215
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
