Go Back   MBWorld.org Forums > Technical & Vehicle Assistance Forums > Mercedes Tech Talk
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : Pelican Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-16-2012, 05:38 AM   #1
Drives: 2001 ml320
Ml320 issues :(
Hey all. Joe green here in sandia tx. My wife and I recently bought a 2001 ml320 with 160,000 miles on it. Really clean car and ran great for a month. I noticed after about a week of use that it began to miss. I did some digging around and found the plugs to be in poor shape. I promptly replaced them and the issue subsided for another week or so. Then returned.
At the same time I noticed it began going through coolant. Suspecting (around a quart a week apr every 300mls) a small leak. I simply replenished the coolant and continued looking for spots on the ground. But never found any.
Two days ago my wife was leaving the house to run errands while I sleeper for work. She came in soon after histericle and babbling on about white smoke ad what not.
I pulled the truck home and checked it out. And notified the dealer from which I purchased the merc. (used lot) the owner says he is willing to help me out with the repairs so I am looking for basically a break down of what the cost would, could be at the dealer for what I suspect is a head gasket failure and possible need for bearings as well. Or if anybody here has had a similar issue and what their end result was. Thanks a bunch folks.
To remove this ad, register today or login if you already are registered!
Drillerjoe is offline   Reply With Quote
Old 04-21-2012, 04:17 PM   #2
Drives: MANY
Coolant useage and white smoke usually point to a failed head gasket. Not too common on m112 engines but I've seen it once or twice. Work case scenario is a bottom end failure. I've also seen the aux coolant pump next to battery leak onto exhaust and eventually cause a fire. Did you clip the pump back into its holder after doing plugs?
NJProTech is offline   Reply With Quote
Old 04-21-2012, 05:54 PM   #3
Drives: 2001 ml320
Well the truck is at Mercedes now. Honestly don't know much about this thing I'm a jeep man lol I build my own bumpers and fab junk up and I can rebuild most any American motor along with bmw's but I do not recall the need to unclip any device under the hood doing the plugs.
Tags
160000, 2001, gasket, head, issues, job, mercedes, miles, ml320, replace, reviews, service
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
