722.6 07 transmission Friction Plates
1 Post
WHITE E320 1999, GruppeM Intk, E55 TB, Evosport Pulleys, Longtube Cer. Coat Headers, Cat/res Delete
Im rebuilding my Tranx. The torque converter failed and made a mess.
My transmission (722.607) comes with double sided friction plates, i was wondering if anyone knows if i can fit single sided friction plates from the newer models? This ones are better cause there is more friction area.
It seems in this manual that they are compatible, but im not 100% sure...
http://www.all-trans.by/assets/site/...es/722.6.1.pdf
any word?
any word?
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Pretty sure you can change to single sided frictions but unless you're planning to add a supercharger or changing to a V8 I wouldn't worry about upgrading, they can handle the torque just fine in standard configuration. Make sure you replace both one way clutches while it's apart.
1 Post
Well, my car is a little modded. It makes near to 250bhp. Im not planning to supercharge it in the short term, i have a m113 e37 engine to swap on.
It would be better to update de frictions now that the transmission is disassembled, the cost for both friction kits is the same.
Do you know of anyone that have done this before?
