w211 fault codes help needed.
W204 2007 CDI 220 125kw auto
Hi,so i have 2007 w211 2.2l 125 kw merc.Suddenly i got a message on cluster saying 'esp inoperative...' and also 'run flat indicator inactive' as well when i press my brake pedal to the bottom the 'hold' pedal function is innoperative also..
i have done diagnostic and getting these errors;
47D4-can bus signal;actual value of outside air temperature not available from instrumental cluster'-permament
430A-stop lamp switch circuit-permament.
Just to say that outside temperature sensor wasnt working for the last year(temperature jumping upand down,never states actual one)
also brake lamps work fine..
Any help on these is highly appreciated!!
thank you in advance!!
(also when clearing these faults they appear once i start driving.
