How to bleed a B200T coolant system
Old 10-01-2015, 05:35 PM
John.Michael's Avatar
2006 B200T
Does anyone have experience to share in how to bleed the air out of a B200 coolant system? ie, What's the best way to do it without using a vacuum purge kit? Are there actual bleed valves on the engine, or is it self-purging? That kind of stuff.
In connection, I'm also wondering where the coolant high point is. It looks to be the heater hose at the temperature valve on the passenger side firewall (and of course the filler tank nearby). I'm guessing that the cabin heater core is slightly lower(?). I'm getting prepared to install an inline coolant heater into that passenger-side heater hose before winter and would like to know what I'm doing before I start cutting. Thanks.
Old 07-25-2020, 03:12 AM
Markgrice's Avatar
B200T
B200 bleeding cooling system
I have a b200 Petrol turbo which had a intermittent overheating problem, fitted new thermostat and electric heater water pump. I have used a bore scope to check the mechanical water pump, impellor is intact and seems OK. I have vacuum filled the system. When starting from cold, temp guage rises steady to 90ish, but no heat to heater and rad still cold, coolant just doesn't seem to be circulating. If I take the car for a drive, the temp guage is off the scale within a minute. Could this still be an air lock problem, is there a spacial way of doing it?
Old 07-25-2020, 06:56 AM
member
pmercury's Avatar
CL
biker349 (07-25-2020)
Quick Reply: How to bleed a B200T coolant system
