Sign in using an external account
| ML55 AMG, ML63 AMG (W163, W164) Discuss the ML55 AMG and ML63 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Paddle Shift Conversion
#2 |
Drives: Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Hi Jo
I had an initial problem that the downshift button wouldnt work a day or two after i had the job done. Turns out a connection was a bit loose from paddle wire and with some super glue the connection was made more permananet. No problems since. I cant understand how your problem would have arisen. Its not like the connector from the paddleshifter could be plugged into the wrong connection??
__________________
![]() Vath V63RS 07 ML63 HRE M50 Mille Miglia ex Brembo GT kit Expression Bodykit Brabus B63S 09 C63 19" HRE Comp 20 Weistec Stage 2 Cargraphic LTHs Revozport Vath Kicherer CF Drexler LSD Macarbon CF interior Mille Miglia ex Dads CF hood Boca intake 09 SL63 Revozport CF HRE 597R Defilipo LTHs Weistec Stage 2 Prior hood 08 CLK63 BS HRE Comp90 Weistec Stage 2 DTM wing Defilipo LTHs Vorsteiner lip Custom hood 12 C63 BS Kleeman SC |
#3 |
Pretty hard to Fk it up or plug it into to the wrong place. I even re-installed the old shifter button and it does the same. + shifts down.
#4 |
Drives: 08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
Sorry didnt experience this problem although we had to splice the connectors as the ones on the paddles were not the same as the orig. It worked right away though....
#5 |
We spiced them as well and even reversed them to see if that fixed it....nope. I guess I only get to gear down for now. hehe
I'll be taking it in to MB to see what they say. |
#6 |
spiced - lol spliced.
So today I took it into MB for them to look at it and what a waste of fkn time. Here are the notes on the work order for the tech "115570 CONFIRMED CUSTOMER INSTALLED PADDLE SHIFTER (AMG) ON STEERING WHEEL ONLY DOWNSHIFTS. PERFORM STAR DIAGNOSIS QUICK TEST. NO CODES STORED. CHECKED FOR ANY POSSIBLE CONDING CHANGES TO MAKE THEM WORK - NONE FOUND. AS PER PARTS ADVISOR, ORIGINAL EQUIPTMENT IS 2 BUTTONS ON EACH SIDE (ONE FOR UP AND ONE FOR DOWN) is this guy a moron? 2 buttons on each side? I even had the original buttons on the passenger seat. I asked the service advisor what to do now and she said she didn't know. Maybe time to go another dealership? |
#7 |
Drives: ML63 AMG, FPV FG F6
Hey I have a similar problem I think.
Try installing the original button and see if they shift like a normal Benz, e.g. one end of the button goes up and the other end goes down. Driving me nuts. |
#8 |
I did and it does the same thing. both down shift
#9 |
Drives: ML55, C32 (sold), R500, Ducati 749 (sold and bought kids), P-c4s
check the plugs
I know when i was playing around with this, on each side there's 3 wires to each. The new paddle's only uses 2 of those wires per side.
So ensure that when you installed the new or old, you didn't cross the wires, or bent the prongs that plug in? I even remember that when I did the mod, I spliced, and just tapped 2 wires together to make sure which ones upshifted and downshifted...pretty sure it's just that. good luck bro. |
#10 | |
Quote:
#11 | |
I was working on my R not ML
Quote:
Sorry I'm of no help bra. |
#12 | |
Quote:
I im in the middle of changing over from button to the paddles and I have 3 wires, Blue Green and Red whereas the new paddles only have 2 wires each. Do you know what wires go where?? Thanks |
#13 |
what is your email address?
#14 |
*edit
#15 |
Very helpful, but which wires are the blue and red hooked up to?
Its 12.07am and im tempted to go do it now, its been bugging me all day. Shame you can only test it with the car running and go for a drive
#16 |
Success!!
Justin you are a legend! I wired up the paddles using red as the hot wire and blue as the ground and they are working 100% !!!!!! |
#17 |
#18 |
Drives: 08 GL550
do you have the part nuumbers for the paddles?
I have a 08 GL550 that I want to convert.. one side is up and one is down. thanks.
__________________
#19 | |
sorry
Quote:
1. remove airbag, 2 torque screws behind the airbag, one on each side 2. remove the small torque screw that holds the shifter buttons in the back 3. I put the airbag in a plastic bag, and just let it sit on top of steering wheel...and didn't even bother unplugging, didn't want any air bag lights to come on 4. i telescoped the steering wheel all the way out, and just took a razor and cut to enlarge the hole... 5. Wired it up. I forget the colors to each, but it is easy to figure out. Turn the car on, put it into drive (ensure airbag is plugged up or errors will occur), of the 3 wires on each side, tap 2 of them together, if they do nothing, wrong wires, if they go up or down, those are the pairs to use since you're going from 3 wire to 2 wire for paddles. 6. Now, the screws wont work anymore, so just find a good plastic epoxy and glue the new paddle into the steering wheel. took about 1.5 hours total. |
#20 |
Drives: W203 C200K-2003
Hi there, I will shortly retrofitting Linguatronic in my W164 2006 and I was in need to get a new set of steering wheels button with the linguatronic fonction.
Here in UK they are expensive (£180 each), so I got a complete leather steering with buttons on Ebay from USA. My intention was just to swap the buttons on the S wheel for the linguatronic,but because the Ebay S.wheel is mush better and newer, I would like to swap the complete S.wheel. On my existing S.wheel I can shift gear + or - on both sides, but I noticed on the new one that the paddles shift only one way on both sides, to make it clearer the existing paddle have two way switch but the new ones have one way switches on both side. I have not removed yet the existing steering wheel to see if there is three or two wires coming from the paddle, but the new one has two wires (red and blue). Is this going to be a straight swap over ? Thanks Last edited by hercules; 01-03-2011 at 04:06 PM. |
#21 |
Yes, if you currently have the rocker buttons (+ & - on both sides) you will have 3 wires.
It's easy to wire up the new wheel/buttons by you just need to know which pins to use. I have a good photo that enabled me to do this and install AMG paddles. I'll have a look for it and post up when i find it |
#22 |
Thank you,
Very much appreciated. OK, just found this in Web ETM Star Browser , one paddle connector in pin 1 &2 is - and GND and the other paddle connector in pin 1 and 2 is + and GND. So if I leave the connector as they are , hopefully it should be OK if not All I need to do is swap one of the paddle connector from pin 1 to pin 3. Is this all right ? Last edited by hercules; 01-03-2011 at 05:29 PM. |
#23 |
Right side of steering wheel
![]() Left side ![]() So considering your new wheel already has 2 wires I think it should be plug and play. For people like me who had to convert 3 wires into 2, the pics above show what pins are used From memory there is a yellow, black and green wire. Get rid of the green wire, splice the yellow with the red and the blue with the black Last edited by schmick325; 01-03-2011 at 06:00 PM. |
#24 |
Quote:
#25 |
Ahh well if u have any problems then you know what changes to make.
Mine works 100% When fitting it, remember that the gears only go up and down when the car is driving. Doesn't work when sitting and idling |
| Tags |
| 2007, 63, amg, button, c63, conversion, ml, ml63, paddle, problem, shift, shifter, shifts, upgrade, w163 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
