ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
'09 ML63 "Headbolt replaced"
Old 07-25-2014, 05:36 PM
sbaer's Avatar
2016 GLE63 with U21; Old: 2012 ML550 , ML63 2009 - E550 W212 2010
I looked at a '09 ML which is obviously in the affected engine range and the MB dealer says the VIM record shows a head bolt replaced at 50k miles but he does not know if this means the TSB for the head bolts and valve buckets was executed.
I don't believe the official service guide allows for replacement of a single head bolt so should I assume the TSB was done and this is now safe?
The only number listed next to the head bolt item is "00120306-7"
Old 07-28-2014, 11:16 AM
MLGuy's Avatar
Looks like the new bolt part # is listed in this thread:
https://mbworld.org/forums/c63-amg-w...olt-issue.html
Also, where did you check to see if your VIN was in the affected range? I've also got a 2009 ML63 and interested to check.
Old 08-09-2014, 09:37 PM
sbaer's Avatar
You can create a free Startek Info account with MB and search the VIN. It will then show the engine serial number
Old 08-14-2014, 08:01 PM
MLGuy's Avatar
Thanks.
Old 08-17-2014, 06:32 AM
red60R's Avatar
2017 C63S
Mine's an 07, so am I to assume it's definitely on the list? At almost 100k I'm going to have to look at the history to see if it was ever done in the past.
Quick Reply: '09 ML63 "Headbolt replaced"
