ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Lowering the ML63 and Ride Quality
Old 05-12-2016, 04:19 PM
GabL's Avatar
2011 ML63, 2007 S2000
Nice ride there Nanook!!
Would you mind advise which brand you go for your "link lowering kit"? As I saw a few on the market, Ghost Link, Adjustable Link, etc... and not sure if they are all the same (some are adjustable some not), so would like to get your input.
I have a 2011 W164 ML63, thinking to lower it a bit as it just sit too high while I'm not doing any offroad with it. Thank you!
Gab
Originally Posted by Nanook
How does my 650 hp ricer look ? (lowered with links)
Old 09-22-2016, 12:46 PM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
Just doing mine now, making my own rods using 10mm ball and sockets.
Fronts longer 7mm drops it nice just but the rear is to much and bounces down the road.
just about to make the rears longer.
Old 09-22-2016, 01:37 PM
zenman63's Avatar
All seems well at 4mm on the rears, it must be the electronic dampers not working so I guess it could be set lower and Star set it.
Old 01-04-2017, 02:32 PM
markmassive's Avatar
2011 ml63
what's your trick in removing the stock links? I am having a hard time taking mine out and I don't want to break the sensor.
Old 01-05-2017, 08:38 AM
zenman63's Avatar
I used cir clip pliers and just squeeze them behind the ball socket and they pop off.
Old 01-06-2017, 12:04 PM
Pee Don Yu's Avatar
2011 ml63
I put the links on. Now I'm having a malfunction error and the switches don't work. What to do?
Old 01-06-2017, 01:00 PM
  #32
2011 ml63
i also installed lowering links but now my rear suspension is not working. I got a malfuction error but when i turn the car off and turn it back on the error is gone. also When i i press the airmatic button to raise or lower it doesnt stop raising or lowering on the command cluster, but it doesnt even lower or raised.
Old 02-22-2019, 05:27 AM
  #33
IRL63's Avatar
Ml63
Lowering link installed now air suspension not working
Hi, did you fix your fault with your suspension? I’m having the same issue after installing my links. Even after putting back in the old/original links, the suspension won’t raise up or down in the rear although it does raise and lower in the front. It also would adjust between sport+ And comfort mode??
Back rear drivers side tyre is 10mm off the arch while the other side is around 25mm ... frustration
Quick Reply: Lowering the ML63 and Ride Quality
