New Member..HELP ML63 Problem Out the WaZoo!!!
Hello, I purchased a 2009 ML63 with 45k miles about a month 1/2 ago that Ive only driven 3 or 4 times. Do to a very annoying whizzing like sound coming from the engine once it heats up. It was wrongly diagnosed as a few bad pulleys and belt. Next WRONG diagnosis was Harmonic balancer which took over a month to get from MB Germany because there was none in the states so they actually had to make me one.. So here I am now with All new pulleys and belts and a new Harmonic balancer and the Damn car still is making the Sound and the Mechanics are Stumped.... Help Please!!!
Assuming since the mechanic replaced the pulleys the noise is in that area. Run vehicle with belt off and see if noise is still present. Could be component like steering pump, alternator, etc. pcv valve/hose are also know to make noise as well as front transmission pump. Going off of whizzing noise like you stated
