ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
GLE63 S Coupe 22" Wheels
Old 10-14-2016, 01:06 PM
Royce63's Avatar
'12 Camaro '09 C300 '14 Jeep SRT '13 650i Gran Coupe '13 ML63 AMG
I have a 2013 ML63 AMG and I want the 2016 GLE63 S Coupe 22" Wheels installed on my car. I'm currently running 265/45/20 all around. Would it fit flush or would I have problems?
Old 10-15-2016, 09:04 AM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
The only way is to look at the ET on you stock wheels and the wheel you would like to fit.
Old 10-15-2016, 02:24 PM
Soamv8's Avatar
2013 W166 Ml63 2008 aston martin vantage roadster
Front wheel will fit just like the stock 21" wheel they have the same offset , rear one should fit but it will most likely to be flush with the wheel arch cause the rear 22" of the gle63 has a lower offset (ET 42) and extra rim width (11.5" compare to 10"),you might need a spacer at the front to make it good right
Old 10-22-2016, 11:13 PM
Royce63's Avatar
So the rear is going to stick out too much?
Old 10-22-2016, 11:14 PM
Royce63's Avatar
Is there any way I can find the ET without taking the wheels off?
Old 10-23-2016, 12:06 AM
Soamv8's Avatar
I think it will stick out about10 mm
Old 10-23-2016, 11:17 AM
Royce63's Avatar
Oh ok, so I would have to run it 305 instead of 315?
Old 10-23-2016, 08:28 PM
Soamv8's Avatar
The problem is not the tyre size , it's the rim will stick out
Old 10-23-2016, 08:30 PM
Soamv8's Avatar
Unless you do a fender extension
Quick Reply: GLE63 S Coupe 22" Wheels
