AZNOptics.com Auto Lighting Storefront
#51
SPONSOR/MBworld Guru
Formally announcing that all our V3 units have not been adapted with Gel Packs. This is a high temp resistant gel substrate that we've applied to the resistor and critical solder joint to both help encapsulate the heat and insulate against heat soak, making these units more durable against heat and electrical surge related incidents.
#52
bump. We'll be introducing a new line of H7 and H11 plasma LEDs in the next few weeks. These would be ideal for fog lights if you don't want to upgrade to HIDs. Package will be put together with big Morimoto load resistors.
#53
03 C320 (For Sale), 08 Audi TT
Keep me updated, I'd like to pick up the H11s for my Audi!
#54
W221 S550 , E46 BMW M3
#56
Introducing new H7 and H11 Plasma LEDs that are ideal for w204 fogs (H7 for Sport, H11 for Luxury). These kits will be paired with new big block Morimoto Load Resistors. These retail for $60/kit
http://www.aznoptics.com/index.php?m...products_id=91
http://www.aznoptics.com/index.php?m...products_id=92
#59
Your GL rear plate uses a set of 36mm festoons. Unfortunately, you (and later model ML and G) will have issues finding plug and play units for rear plates because in 2008, Mercedes augmented the rear SAM, tightening up the current draw feedback loop causing pretty much all canbus LEDs on the market to not work. We've ran into this a few times before identifying which models and year have this augmented SAM. The challenge is that to make a built in solution work, we'll have to now draw more current to trick the SAM, but doing so will cause more heat on the unit which introduces a lot of other potential issues. For now, people with your model and want LEDs have to resort to external resistor tapping.
#61
AZN, I just recently installed some license plate LED's on my 06 E55 and they look KILLER! Thank you for a great plug and play product.
Do you offer anything for the foglights on the W211? As of right now, they're the only light on the front of the car that are "yellow" and old looking compared to the Xenons/LED's on the driving lights.
Thanks in advance!
#62
Thanks in advance!
Thanks in advance!
#63
New V5 design is now available. These utilize cooler burning COB based diodes matched with our surge protection circuitry from our V4 line.
Offered in 4300K (matches better with OEM halogen and older HIDs) and 5000K (pure white)
4300K: http://www.aznoptics.com/index.php?m...products_id=96
5000K: http://www.aznoptics.com/index.php?m...products_id=95
#64
#65
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
#68
I've got a 2008 CLS and want to replace the overhead lights (reading/map...), which I believe are festoons. Do you know what goes there, and do you have them?
#69
Sharing a pic provided by one of our customers of our new V5 194 wedge LEDs and the level of brightness the new design has with just the city lights by themselves.
#73
bump
Working on adapting our V5 design to festoon models which should be available January.
