WTB: front side marker bulb holder & "male" foglight plug assembly
02' C32 - 07' H2 - 07' BMW K1200R
Hi,
I'm trying to get hold of the 'harness' or holder that the side marker bulb sits in. Dealership says it is only sold with a new complete wiring harness
To further clarify, this part holds the actual side marker housing to the bulb - it has the wires connected to it. (passenger side - probably interchangeable)
I am also looking for the "male" fog light "plug"& wires if available. This is the part that clips into the female port on the back of the assembly that holds the halogen bulb. (drivers side - probably interchangeable)
Please let me know if you have either or both you are willing / able to part with.
If nobody has any - could you point me in the right direction where I could buy them?
I need the part in the red box and some wires if possible : )
I need the entire "white" assembly that holds the bulb and some wires if possible : )
2016 C450
That sidemarker socket is sold at the dealer as a repair kit. It is very cheap. And if that socket is all corroded then your sidemarker lens will also have to be replaced. It's leaking water.
