WTB: OEM Hella E55 Bixenon Projectors
Looking for a set of OEM Mercedes projectors (specifically, Hella E55 bixenon projectors). Preferably working, but I'll consider non-working as well.
I'm particularly interested in the cutoff/foreground limiter shields & Fresnel lenses for a retrofit project.
Hit me up if you have a set.
wish I would have seen this sooner...
I threw out my fresnel lenses after I had swapped them for clear lenses... Any reason you want frensel over clear lenses? My cut off drastically improved along with color intensity with the clear lenses.
Good luck!
-Nigel
Good luck!
-Nigel
I was planning on using evox-r projectors with the fresnel lenses to eliminate streaking but I think I'm going to go the opposite direction - oem E55 projectors with zkr lenses
Nice! You will like the ZKR lenses. That's what I put on mine.
Two ****ty pictures so you can see the difference.
First picture stock fresnel lense, second with the ZKR. Also vastly improved via the high beam feature of the bi-xenons... it's like God is shining a flashlight when the brights are on...lol
The color flicker with the clear lenses is intense.
-Nigel
-Nigel
Moderator Alumni
I have a set of oem w203 bix w/ projectors and everything. Only downfall is that im pretty sure the ballast and/or the ignitors are dead in them. Let me know if you're interested.
Thanks,
Thanks,
I have a drivers side headlamp with broken clips
https://mbworld.org/forums/exterior-...-headlamp.html
Works perfectly other than the clips.
