Illuminated Star ....mounted!!!!
Old 09-24-2013, 10:14 PM
im4umia's Avatar
2012 Mercedes CLS 550
Originally Posted by wally AMG
Installation was breeze, very easy, just time consuming (about 2-3 hours) easy on me !! I am not a tech !! if you want to do the things right, run the wiring nice & neat (like factory).
Run the star on all the time I don't know, I like the way it is, running the star on all the time is a little show off for me but it is a taste issue... maybe you can tap with your headlights..
The LED Star parts do not come with instructions. Curious.... how did you know where to run the wiring?
Obviously if you were going to have them turned on all of the time you'd jump the existing LED's or headlights. However, sounds like you did the 'factory' install. How did you do this?
Thanks!
Old 09-24-2013, 10:29 PM
im4umia's Avatar
Originally Posted by Freddythedoc
is'very simple .... partially open the plastic cover on right fender. In this way you can see from underneath the large plug that carries current to the entire lantern. Than with a tester you find the positive wire of the position lamp...than with a current tap like you see in the picture you cm take the positive wire for the dimmer. The negative wire from the body car
Hello Alfred.....can you please tell me where you physically mounted the dimmer box?
Old 09-25-2013, 01:41 AM
Freddythedoc's Avatar
Mercedes ML W 166 Premium 250 Bluetech
Under the black plastic cover in the right angle of the motor-box
Old 10-08-2013, 12:13 PM
skw
skw's Avatar
2019 GLS450
Has anyone noticed that the new '15 Escalade has the Cadillac wreath on the grill that glows in the dark?
Old 12-18-2013, 07:37 PM
Another little clip ......the bright star seen from very close!!!!
Old 04-18-2014, 11:01 AM
SEXYBEEST's Avatar
wife's car2014 ml350
has anyone else installed the illuminated star yet
Old 04-18-2014, 12:36 PM
  #32
GregGebhardt's Avatar
2014 ML350 BlueTec
I am interested for sure but would want it to stay illuminated at all times while driving.
Can this be ordered from our local dealers?
Old 04-18-2014, 02:12 PM
  #33
stas2007's Avatar
2013 ML
I installed mine, very easy i just connected it together with LED fogs,mine is on all the time.
The new illuminated star kit mercedes released is always on(it doesnt come with any module and just connects somewhere in the fuse box)
Old 04-18-2014, 03:55 PM
  #34
2014 ML350 BlueTec
We can I get in the USA
Old 05-02-2014, 03:34 AM
  #35
rEkyAh's Avatar
2012 ML350
Anyone willing to post a Step by step guide with pictures? lol
Old 05-02-2014, 05:00 AM
  #36
2014 ML350 BlueTec
I am doubting that I can do this as I understand that my Distronic uses this dish/star.
Old 05-02-2014, 11:46 AM
  #37
jtorrebl's Avatar
2020 Panamera GTS
Yep no go for you.
Old 05-02-2014, 03:29 PM
  #38
27T
27T's Avatar
13ML BT
A few months ago I saw an MB pass by with the star lit. Personally, I thought it looked tacky.
Old 06-13-2014, 11:01 AM
  #39
elveston's Avatar
'13 ML550, '08 ML320cdi (retired) & '99 ML320 (retired)
berglundluxury on ebay
The new Mercedes kit is configured for full time illumination of the star. Not being opposed to a little more "bling", I decided it was time. Berglund Luxury (a Mercedes dealer) sent a copy of the install instructions before I ordered, so I knew it would be a lot simpler than the original install. By the time it arrived, I had already studied the instructions and checked out my ML550 setup. The instructions indicate a foam piece between the radiator and frame, but my ML had a hard rubber strip. I used a fishtape to route a small wire at the top of the rubber piece from the fuse box to the grill. I taped the fuse connection/ground to the wire, and pulled (carefully) back from the grill into the engine bay (instruction call for going the other way). Surprisingly easy.
The rest was per instructions. The fuse holder is a little loose in the box, and may require a shim or similar adjustment in the future, but the Star is illuminated. I haven't had it out at night, yet. But, in the daylight, it is not noticeable.
Old 01-11-2015, 01:11 AM
  #40
Hungedu's Avatar
2007 CLS-550
Does anybody here know how I can modify the OEM illuminated star kit to fit a 2007 CLS-550? I've been to the dealer, but they tell me there is no kit for my car, only newer models. I thought the star medallion on these cars are pretty much the same diameter. My belief is that it should be possible to modify an illuminated star kit intended for another model and make it fit my 2007 CLS. I have no idea where to start or who to ask... I WANT ONE OF THESE, GHETTO LOOKING OR NOT! :-)
Quick Reply: Illuminated Star ....mounted!!!!
