2015 ML Cargo Net Options
2015 ML 350
Does the 2015 ML come with cargo nets at all? I'm talking about the spider net on the cargo floor or a V Shaped Grocery Bag vertical net across the door opening?
If they are available after delivery, are there the necessary hooks in place from the factory to attach the nets later after buying them from the Parts department? ...or must they be factory ordered for the hooks to be there?
Thanks.
Thanks.
2014 ML350 4Matic
A cargo net that covers the floor is available from the dealer parts department as an accessory. It attaches to existing anchor rings on the front of the cargo floor and the rear pillar area to the right and left of the cargo floor.
2015 ML 350
Good to know! Just wanted to be sure the anchor points to the vehicle were already there even though the net had yet to be purchased. Thanks again.
2014 ML350 4Matic
I need to make one correction to my earlier post. At the rear the M-B accessory floor net has pockets that slip over the rear corners on the load floor. It has hooks that attach to the load floor rings at the front.
On my ML I have the cargo area tray AND the cargo net. The tray makes it impossible to use the pockets so I attached the rear of the net to the rear rings with some short bungee cords.
2015 ML 350
