Allignment issue on 2012 Ml 350
Hello. I need you opnion. I replaced my 4 tires after 39000 miles with the same brand on my 2012 ML 350. I noticed a uneaven wear on the front tires more than the back. I was told to take it for an specialty aligment here in Houston. SW alignment supposedly thet do a great job. The TECH kept trying to adjust it and take few time for drive to no avail. I was told it need the Camber caster bolt repaced. got the bolts from the dealer and they installed them but still the same problempulling issue and they cannot adjust the pull.The SUV still pulling to the right.rotate front front tires and still the same issue. The guy told me may be the computer has an issue.... Does anybody heard of computer issue that could be an issue? I am taking it to the dealer now. what you guys think? A recommentation is greatly appreciated.
Thank you
Thank you
SPONSOR
KEEP IN MIND THE ONLY OEM ALIGNMENT IS FRONT AND REAR TOE!
Slotted bolts are inaccurate one position allowing only 1/8 inch offset.
With K-MAC the statement “Full front and rear alignment” means what it says.
The (ongoing) capability to precisely adjust "dial in" front for Camber to resolve costly premature inner edge tire wear/improve traction. Caster to resolve steering pull, improve steering response with better turn in and directional control.
For the rear also, Camber with extra Toe adjustment to compensate for the new Camber facility.
Special freight deal MB World Members USA/Canada next 4 weeks $30 one kit or $40 front and rear kits.
